HRW 1/25TH Vintage NASCAR SERIES – Land Barges & Zippertops! – 2026 Winterfest Showdown
SATURDAY, JANUARY 17th  – 2026!
*Mail in deadline – 15 JAN*
Do NOT wait to mail. Remember the weather CAN AND WILL be a factor in your mailing times.
Our guidelines are a mix of beginner and veteran modeler skill levels. The goal is simply to get YOU involved in the fun this larger scale has to offer. Hopefully it also motivates you to start more scratch building.
ONE CAR PER CLASS ENTRY ONLY.
Entry Fee: $10 per car. PAYPAL HERE
This series covers a small time frame in NASCAR history.  We are modeling what we jokingly refer to as “land barges”.
Those late 59 to 64 cars that were long, lumbersome, and likely the worst candidates to make a race car with.
We also are featuring the famous convertible (aka zippertops) series. This was a short-lived but popular one that featured some incredible racing.
For these ZIPPERS: We are modeling the main 4 year period ONLY. 1956 to 1959.
So you can model ONE of each for the event.
ONE Land Barge with the year rule of 1959 to 1964.
Car MUST have raced in the series. It does not need an accurate team or precise #, but the car type itself must have raced in the series ie: (Ford Starliner, Merc Marauder, etc)
NO El Caminos, Nomad or other station wagons, Trucks, Cadillacs, Lincolns, Hearse, VW’s, Vettes etc. Not sure? ASK. Or Google is your friend.
It is a CLASSIC NASCAR event.
ONE Zippertop! with the year rule 1956 to 1959. This was the main 4 year series. Although they did have special events at Darlington, etc until 62, we are sticking with the MAIN 4 YEAR period.
AGAIN, car must have raced in the series. Common sense and research BEFORE buying a kit is highly advised.
You CAN create fictional paint schemes BUT they must appear period correct. In other words, look like they COULD have raced during that time period.
The Track:
Our Track – Please click HERE for The Show-Me Speedway in depth look
Show-Me Speedway
5 x 16 foot, 4 lane, routed MDF.
Track Surface: Satin Latex
Lane Spacing: 4 1/16 Inches
Slot Depth: Shade over 10 MM (any commercial or wood guide will clear)
Straight Length: 10 feet.
Rails: Slot Car Corner tinned copper braid.
Power:
Aftermarket 25 AMP
Control:
Standard Professor Motor 2120 Controllers
Timing: TrackMate Infrared hardware and TrackMate software.
Chassis:
Brass or Steel/Brass mix only. NO plastic, wood, 3D, etc.
Older Pro-Track or current H&R chassis ONLY are allowed. NO OTHER PREFAB BRANDS.
GUIDE – Any commercial guide will clear.
8.50 MM Slot Depth/Flush briad
Scratchbuilt is the preferred choice but NOT required.
INLINE ONLY – We are making it easy for all.
Mixing steel and brass allowed
NO minimum weight. It’s a barge.
Older Pro-Track or current H&R chassis are allowed. No other brands.
Track clearance: 1/8 is a good minimum to start but can go as low 3/32. SEE ABOVE
I include this minimum due to some of the chassis like H&R being in between the two heights in many cases.
NEW SCC Motor brackets encouraged.
Running Gear:
CB Design Series all around.
H&R/Protrack allowed but must be correct size and width.
You can choose between smooth (ribless) wheels or the newer wheels with inner rib.
Tire width should not exceed 12.5 MM. Which will be no issue as you must use the PG Tires listed.
You can utilize 3/32 or 1/8 axle bore.
Gear ratios are your choice. I will suggest 9/27 or 9/28 as this seems the best on our size oval.
Slot.it, Scaleauto, Parma, H&R, JK gears allowed.
Guide can be larger commercial grade or any Sloting Plus, Slot.it, Scaleauto 1/32 guide.
Your choice of braid.
Tires:
Only Paul Gage tires allowed on rear. Sizes 28125 or 26125
If using smooth wheels without the inner rib, 28120 or 26120
NO OTHER TIRE ALLOWED ON THE REAR
Older foams or older urethane/rubber allowed on fronts only.
Overall diameter should be no less than 26mm. These are not LMP or low profile type cars.
Bodies:
Common sense should be your guide.
1959 to 1964 LAND BARGE
1956 to 1959 ZIPPERTOP
American sedan 1/25th or 1/24th plastic model kit body that they used in the series.
No El Caminos, Rancheros, or Trucks.
I will suggest 1/25th. There is a difference albeit slight in some cases.
NO short box models. That means no Mustangs/Camaros, Vettes etc.
If you find a kit, simply ASK US and we will make the call.
NO resin or clear lexan bodies. Standard model kit bodies only.
Modeling Notes:
This series follows the same spirit as our 1/32 Showdown.
It is about MODELING as much as performance. Try to recreate a car that would look the part on the track during that time. Added scale detail is HIGHLY encouraged!
Wheels/Tires must be INSIDE the body. NO enlarged fenders or flares.
Must have interior. Simple flat stock with driver and roll bar accepted.
NO lexan formed trays. They look horrible and this is about MODELING as well as performance.
Must have glass in place. Either kit or clear plastic you had to make.
Body to track clearance should be 1/8 and not to exceed 3/32. Any lower and you risk dragging.
Models will be painted to match the style NASCAR used at the time. Either model a 1:1 prototype or create your own style.
Again, common sense here. There is no shortage of photographs for you to use as a guide.
Wheels should look like the time period. Basically plain steel wheels.
Either inserts or the CB Design Steelies.
NO LMP or any style wheel patterns that do match the time period.
Building Links courtesy of Slot Car Corner
Motor Brackets
CBD0690 CB DESIGN 1:24 CLASSIC STEEL WHEELS, 3/32” AXLE, CENTER RIB
CBD0692 CB DESIGN 1:24 CLASSIC STEEL WHEELS 1/8” AXLE, CENTER RIB
CBD0694 1:24 CLASSIC STEEL WHEELS 1/8″ AXLE, NO RIB
CBD0696 CB DESIGN 1:24 CLASSIC STEEL WHEELS, 3/32″ AXLE, NO RIB
CBD1650 CB DESIGN 1:24 NARROW INSERT WHEELS 1/8″ AXLE, CENTER RIB
Assorted Crown Gears both 1/8″ and 3/32″ Bore
Assorted Pinions 1/24
Assorted Pinions 3/32
1/8 Axles and spacers
3/32nd Axles
3/32nd Crown Gears
Motor and Body Mount Screws
1/32 Style Guides
1/24 Style Guides, Braid, and Wire
Assorted Brass Rod
Assorted Brass Strip
Assorted Brass Tubing (Rectangle)
Assorted Brass Tubing (Round)
Assorted Brass Tubing (Square)
Assorted Piano Wire
CONTACT US WITH ANY QUESTIONS
Jorge
Dave
But just use the forum for faster answers!
