2026 “Summer Breeze” Show-Me Showdown
SATURDAY – July 18th 2026
Fast Laps/Shakedown 16-17
Mail In Deadline WEDNESDAY 15 JULY
Entry Fees and donationds for this event can be sent here.
LIMIT ONE CAR PER CLASS
(One Sportsman – One Strangebrew Mod)
INTRODUCTION
4. – Entry Fee – $10.00. You can simply DONATE HERE for these.  If you are sending from outside the continental USA, we will work with that as well.
List of Events
Held the Friday before the event. We test every model and report live on the forum.
***IMPORTANT***
I do not have the time to rebuild your car. We will test the model and if it runs then that is how it will race. In other words: take your time and setup your car properly.
Our Track Info
1/32 Race Divisions
1. Sportsman – The standard full fender body styles.
We are combining the older classics with modern late models.
2. StrangeBrew Modifieds – The famous modified series.
Inspired by the modeling of our own “Strangebrew” Dave.
YEARS 1954 – 1990 American Sedan
APPROVED BODIES FOR SPORTSMAN CLASS
ALL NEW 3A3D and other 3D resin prints approved.
Check the link at Slot Car Corner for availability.
Atlantis 1/32 Models Not the drag models but Nova, Camaro, Firebird etc.
AMT Scale Stars Thunderbird.
– Carrera Classic NASCAR Ford Torino, Plymouth Road Runner, Dodge Charger. *** No Wing Cars ***
– Carrera 57 Chevrolet, 60 Plymouth, 70 Chevelle, early release GTO, Mustang
– Revell/Monogram Classic NASCAR – Galaxies, GTX, Charger, Fairlanes, Vintage 69 Nova kit
– Scalextric -70 Camaro, 69 Camaro, 69/70 Mustangs, Challenger, Cougar, 69 Charger, 72 Torino
NEW MONTE CARLO AND THUNDERBIRDS!
2010 Camaro and Mustangs, and new 60’s Stang.
– Pioneer Charger/Mustang/Camaro
– SRP 55 Chevy, 56 Ford, 70 Chevelle, 69 Nova, 57 Nomad
– SCX Cuda
– MT Racing Resins – 70/71 USAC Racer, 69 Nova Sportsman, 65 Shovelle, Late Model 69 Chevelle. ASA Camaro, Mustang & Firebird
– Gunze Sangyo – 57 Chevy hard top, 59 Chevy hardtop
– Revell Snap-Tite – 55 Chevy, 69 Camaro, 70 Mustang, GTO, 78 Camaro, Firebird
– RMS Resins Nova II, 65 Fury, 65 Galaxie, 66 Chevelle, 65 Impala, 63 Falcon, 67 Cougar, 68 Camaro, 68 Firebird, 70 Challenger, 70 Camaro, 70 Cuda, NEW CHEVELLE & DUSTER
– Skunkworks ShapeShifter – Buick LM, 7123 Camaro, AM Camaro, 65 Ford, MA Cuda, New Bodies as available.
NO CLEAR/LEXAN/POLY type bodies.
This is a HARD body modeling class.
NO El Caminos, Nomad or other station wagons, Trucks, Cadillacs, Lincolns, Hearse, VW’s, Ambulances, etc. Not sure? ASK. Or Google is your friend.
IF you decide to 3D print your own body, you must contact us first.
You will give us the year and model, and make sure it is to 1/32nd scale standards. This will make it very clear that there will be no printing or use of undersized models.
This is a special series that could include many different body styles. See the above photo for examples. If you truly want to enter a model in this division, please contact me with your body style idea. I will ask that your common sense should guide you first. Researching the classic modifieds will give you 1000’s of ideas. And don’t forget CLASSIC.
1925 – 1990 will be the cutoff year for bodies.
Models are from the 60’s to 90’s in design and style.
Unsure? ASK. Google is your friend.
Bodies must be as close to 1/32nd scale as possible. Body shapes should resemble the many prototypes easily researched.
American 2 door or 4 door sedans. Example: 40 Ford Sedan allowed. Cut down 57 Chevy Nomad allowed. COUPES will have any running boards removed and height of body at scale level.
Interior: Must have driver, dash, steering wheel, roll cage detail.
Body Clearance To Track: 3/32″ is a good minimum
Body Width: Keep it stock. You can add flares if you want for scale appearance, but no narrowing of the stock body shell.
MAX Body Width2 5/8. This applies to models with flaring. In other words, no wider than the allowed track width which is 2 5/8″
Body Style: I’ll repeat because some folks….American hardtops cars. No convertibles. No Station Wagons. No Trucks, Vans, SUV’s, Zamboni’s, Semi’s, Street Sweepers, etc. Common sense time.
This is NOT A STREET ROD class. It is an OVAL RACING SERIES.
Body Clearance To Track: 3/32″ is a good minimum. Front spoiler, if used, at 3/32ndThis will make sure the bodies/spoiler do not drag the track.
If during testing your model drags our track surface, I will contact you. I do not have the time to rebuild every car that comes in. If it cannot be a quick shim fix it WILL be a DQ unfortunately.
Must keep all fenders. This isn’t the modifieds. Enlarging/Flaring ok but must keep outer and top edge. See above model photo examples or search late model sportsman. Pinterest is excellent source.
Interior: Must have a driver, dash, steering wheel, roll cage detail. NO pre-molded lexan types.
Windows: Front needs glass or screen, your choice. Sides and rear optional.
Side Bars: Allowed but cannot be wider than the outer sidewall of tires. (2 5/8″)
Brass/Steel Wire Chassis. From scratch, but forged or stamped brass motor brackets and guide tongues are allowed.
SHOWDOWN CHASSIS KIT HERE
INLINE ONLY
USE THE LATEST SHOWDOWN CHASSIS KIT HERE:
Offset motor configuration allowed.
No Slot.it pods or other plastic/3D/hybrid combos.
2 Wheel Drive Only.
Only 4 Wheels.
Chassis to Track Clearance:
 3/32″
MAX Track Width: 2 5/8″ from sidewall to sidewall.
Stagger is allowed. In other words you can run a 15×8 on the left front and a larger size on the right front, just adhere to the width maximum.
The goal is to create as close of a field as possible.
WHEEL AND TIRE SIZES
C.B. Design 15×8, 15×10, 15×11 ONLY
(Insert, Stock Car, 5 Spoke Racing, F1/MOD, & Classic Steel)
If insert wheel used USE AN INSERT
Wheel size chart for reference:
Quick PG Tire selection:
15×10 uses 22166FF
15×11 uses 22168F
The minimum size wheel/tire combination is 15×8 with PG 21125 tires.
This is for the LEFT FRONT only to simulate a “pony” wheel on the modifieds.
-22 or 21125 for 15×8
-22166FF, 22168FF for 15×10, 15×11
REMINDER! MAX Track Width
: 2 5/8″ from outer sidewall to outer sidewall.
USE A SETUP BLOCK AND CHECK YOUR HEIGHT
Tires too far off the surface just causes excess tipping, if the car is simply too hard to keep in the slot, it will be a DQ.
Motors
This series will now be based on the PREDATOR LINE ONLY and only two types below will be allowed.
1. “RaceStopper Award” for Best Looking Car
2. “HRW Haulin’ The Mail” Award for Fastest Lap
3. “Smokey’s Choice Award” for my overall favorite
A complete video series on a basic chassis.
