SATURDAY – JANUARY 18th 2025
Mail In Deadline January 16th
Any donations for this event can be sent here.
LIMIT ONE CAR PER CLASS
(One Sportsman One Strangebrew Mods)
| INTRODUCTION |
4. – Entry Fee – $10.00. You can simply DONATE HERE for these. If you are sending from outside the continental USA, we will work with that as well.
| List of Events |
Held the Friday before the event. We test every model and report live on the forum. If we find any issues with your model, we will contact you and repair if we can. THis way your model will be ready for race day!
Our Track Info
| 1/32 Race Divisions
1. Sportsman – The standard full fender body styles. We are combining the older classics with modern late models. 2. StrangeBrew Modifieds – The famous modified series. Inspired by the modeling of our own “Strangebrew” Dave. |
APPROVED BODIES FOR SPORTSMAN CLASS ALL NEW 3A3D and other resins approved. Check the link at Slot Car Corner for availability. Atlantis 1/32 Models Not the drag models but Nova, Camaro, Firebird etc. AMT Scale Stars Thunderbird. – Carrera Classic NASCAR Ford Torino, Plymouth Road Runner, Dodge Charger. *** No Wing Cars *** – Carrera 57 Chevrolet, 60 Plymouth, 70 Chevelle, early release GTO, Mustang – Revell/Monogram Classic NASCAR – Galaxies, GTX, Charger, Fairlanes, Vintage 69 Nova kit – Scalextric -70 Camaro, 69 Camaro, 69/70 Mustangs, Challenger, Cougar, 69 Charger, 72 Torino – Pioneer Charger/Mustang/Camaro – SRP 55 Chevy, 56 Ford, 70 Chevelle, 69 Nova, 57 Nomad – SCX Cuda – MT Racing Resins – 70/71 USAC Racer, 69 Nova Sportsman, 65 Shovelle, Late Model 69 Chevelle. ASA Camaro, Mustang & Firebird – Gunze Sangyo – 57 Chevy hard top, 59 Chevy hardtop – Revell Snap-Tite – 55 Chevy, 69 Camaro, 70 Mustang, GTO, 78 Camaro, Firebird – RMS Resins Nova II, 65 Fury, 65 Galaxie, 66 Chevelle, 65 Impala, 63 Falcon, 67 Cougar, 68 Camaro, 68 Firebird, 70 Challenger, 70 Camaro, 70 Cuda, NEW CHEVELLE & DUSTER – Skunkworks ShapeShifter – Buick LM, 7123 Camaro, AM Camaro, 65 Ford, MA Cuda, New Bodies as available. NO CLEAR/LEXAN Womp type bodies. This is a HARD body modeling class. * If you create your own resin or 3D bodies, please email me for approval. |
This is a special series that could include many different body styles. See the above photo for examples. If you truly want to enter a model in this division, please contact me with your body style idea. I will ask that your common sense should guide you first. Researching the classic modifieds will give you 1000’s of ideas.
Bodies must be as close to 1/32nd scale as possible. Body shapes should resemble the many prototypes easily researched.
American 2 door or 4 door sedans. Example: 40 Ford Sedan allowed. Cut down 57 Chevy Nomad allowed.
Interior: Must have driver, dash, steering wheel, roll cage detail.
Body Clearance To Track: 3/32″ is a good minimum
Body Height: Keep it stock. Original A/B pillars intact, in other words no low rider/rat rod chopped tops.
Body Width: Keep it stock. You can add flares if you want for scale appearance, but no narrowing of the stock body shell.
MAX Body Width: 2 5/8“. This applies to models with flaring. In other words, no wider than the allowed track width which is 2 5/8″
Body Style: American hardtops cars. No convertibles. No Trucks, Vans, SUV’s, Zamboni’s, Semi’s, Street Sweepers, etc. Common sense time.
Body Clearance To Track: 3/32″ is a good minimum. Front spoiler, if used, at 3/32nd. This will make sure the bodies/spoiler do not drag the track.
Must keep all fenders. This isn’t the modifieds. Enlarging/Flaring ok but must keep outer and top edge. See above model photo examples or search late model sportsman. Pinterest is excellent source.
Interior: Must have a driver, dash, steering wheel, roll cage detail. NO pre-molded lexan types.
Windows: Front needs glass or screen, your choice. Sides and rear optional.
Side Bars: Allowed but cannot be wider than the outer sidewall of tires. (2 5/8″)
Brass/Steel Wire Chassis. From scratch, but forged or stamped brass motor brackets and guide tongues are allowed.
INLINE ONLY
USE THE LATEST SHOWDOWN CHASSIS KIT HERE:
Offset motor configuration allowed.
No Slot.it pods or other plastic/3D/hybrid combos.
2 Wheel Drive Only. Only 4 Wheels.
Chassis to Track Clearance: 3/32″ is a good minimum.
MAX Track Width: 2 5/8″ from sidewall to sidewall.
Stagger is allowed. In other words you can run a 15×8 on the left front and a larger size on the right front, just adhere to the width maximum.
The goal is to create as close of a field as possible.
Click Below To See Wheels and Tire Combos
C.B. Design 15×8, 15×10, 15×11, 15×12, 15×13
(Insert, Stock Car, 5 Spoke Racing, F1/MOD, & Classic Steel) If insert wheel used, please use an insert.
Wheel size chart for reference:
Quick PG Tire selection:
15×10 uses 22166FF
15×11 uses 22168FF
15×12 uses 22166FF
The minimum size wheel/tire combination is 15×8 with PG 22125.
-22125, 22126 for 15×8
-22166FF, 22168FF for 15×10, 15×11, 15×13
REMINDER! MAX Track Width: 2 5/8″ from outer sidewall to outer sidewall.
Motors
This series will now be based on the PREDATOR LINE ONLY and only two types below will be allowed.
A complete video series on a basic chassis.
