Welcome to the Pioneer Legends Proxy. Please take the time to read the guidelines below. We hope you will join the fun!
The FIRST race will be at Ivoryton Raceway. All other locations and dates will be posted in the forum.
Please have your name under your model. We all know how this helps.
Please share the number of turns you have loosened the body/chassis screws if possible.
Remember, it is a good idea to tape over the holes in the chassis to help prevent looser screws from falling out.
Body: Stock Pioneer Legends bodies ONLY. NO modifications. Front windscreen must be in place.Bodies will be properly secured to the chassis using the stock body posts. Stock or aftermarket screws allowed.
Appearance: NASCAR style numbers on both doors. Roof numbers are encouraged but not required. If applying roof numbers, they should be positioned as any NASCAR would be. Sponsor and other decal details are encouraged. Stock Pioneer or builder’s choice on schemes but they must resemble a NASCAR type layout. No racial or political schemes please. Common sense here folks.
Interior: Stock interior must be used and intact. No modifications. Driver must be painted and interior properly secured to the body.
Chassis: The stock Pioneer (Legends) chassis ONLY. Light sanding to achieve good float is allowed.
Minimum Weight: 80g. This is the weight of a box stock Legend. This will be inspected by the race director of the first race.
Adding Weight: You are allowed to add weight. Must be secured and concealed. No weights UNDER the chassis.
Wheels: Stock or CB Design 15×8 size that includes “Stock Car” #CBD1410, and Modified wheels # CBD0755. Insert wheels #CBD1050 with stock Pioneer or scale NASCAR insert. Slot.it 15×8 insert wheel allowed with either the inserts listed above.
REAR Tires: For STOCK rims Paul Gage FIRM compound only part# PGT23103XD, 22103XD, or 21103XD. If using CB Design wheels choose part# PGT 22105 or PGT 21105.
FRONT tires: Stock or aftermarket. Zero grip compounds allowed. No tire coatings allowed. Tires must make contact with track surface.
Width at Wheels: 63MM Max both front and rear.
Axles: Stock or aftermarket allowed.
Bushings: Stock or aftermarket allowed. They may be glued In place. No ball bearing bushing.
Gearing: Stock or aftermarket allowed. Gear ratio is your choice.
Braid: Stock or aftermarket allowed.
Guide: Stock or aftermarket allowed. Adapters such as the CG Slotcars are allowed for aftermarket guides. Removal of digital plug allowed and straight wiring from motor to guide allowed.
Magnets: Not allowed and must be removed. Of course this means no magnets anywhere in the chassis or on the motor.
Motor: Only the stock Pioneer (18K Typhoon) motor that comes in the model is allowed. No modifications.
