How to build a resin kit
Re: How to build a resin kit
Postby dreinecke » Fri Jan 31, 2014 6:09 pm
Oops! Did I forget to put in the instructions NOT to use the coffee table, the dinning room table, or any of the wife's nail products in the build of your resin kit?
Postby goosenapper » Sat Sep 03, 2016 2:12 pm
I used to use Dial to clean prior to painting, but they changed the formula and now it's more greasy feeling than it used to be. I went looking for Wesley's Bleech White as Doc suggested, however it looks like they were bought out and rebranded to Black Magic Bleche White. Reading reviews and rants on automotive forums points to yet another formula change.
So at this point, what are our options when it comes to removing resin release agents :?:
goosenapper
Postby HomeRacingWorld » Sat Sep 03, 2016 2:35 pm
Just some Dawn dish liquid and lukewarm water. Works every time.
Postby waaytoomuchintothis » Sat Sep 03, 2016 2:41 pm
I'll add this little bit... be thorough. There are so many little places that you might miss. I finally started using a toothbrush, after having a couple of screwups.
Postby goosenapper » Sat Sep 03, 2016 2:51 pm
So it's Dawn with a toothbrush. Excellent! I've got a couple of out of production kits that I can't afford to screw up, so this will will come in handy. Thanks guys.
:text-thankyouyellow:
goosenapper
Postby Ky.Slot Racer » Sat Sep 03, 2016 4:20 pm
A trick I read somewhere was after washing, take some regular masking tape and stick it all over the body. If it sticks, the paint will stick. It has never failed since I`ve read that, and began the procedure. If it don`t stick like it should re wash till it does, it will save a lot of grief, especially if you plan on multi colors and re taping.
Ky.Slot Racer
HRW Master Modeler
Postby tin_indians » Mon Apr 03, 2017 7:57 pm
How about a can of computer air? You know, the compressed aresol (sp) can of air to dust your keyboard. It could get the water out of areas you cant get a paper towel into.
tin_indians
Postby Audi1 » Tue Apr 04, 2017 11:27 am
I use 000 and 0000 steel wool on new resin bodies; gives me just the right "tooth" on the surface. Then a wash with Dawn, rinse with lukewarm water, dry and ready for paint. No need for primer unless you need to bury a color.
Users browsing this forum: No registered users and 37 guests
