Road course test track
Got Wood?
Your ROUTED TRACK Home!
Postby Junior » Mon Sep 17, 2012 6:56 pm
I am building a smaller indoor test track for our family room, I currently have a 4 x 16 Suzuka in the garage. I finished the routing on Sunday and only have one area to clean up and that was due to me forgetting which way to go with the router. It is very loosely based on Harry's MidMo road course. I had to make it in two pieces to make sure it actually will fit down the stairs. the track is 11' x 40" and the widest part goes to 48". One section is 80" and the other is 52". Image
Junior
Shop Teacher
Re: Road course test track
Postby HomeRacingWorld » Mon Sep 17, 2012 7:33 pm
Looks great Junior!!!
Nice track for a tighter space. You are quite the arteest!
Postby Junior » Fri Sep 28, 2012 7:37 am
First coat of Chalkboard paint, I am using gray instead of black
I think 3 coats should do it and hopefully will be taping on Sunday!
Norb helped with the bondo'ing and sanding and we routed slots for the walls on the curves.
Junior
Shop Teacher
Postby HomeRacingWorld » Fri Sep 28, 2012 7:40 am
Looking great. Can't wait to race on it.
Make sure to send me copies of the rulebook for this track ok?
Postby Junior » Fri Oct 26, 2012 6:58 pm
Getting closer to being finished. The track is powered but I need to wire some taps to ensure even power. I also need to find some sheet plastic for the walls. Need to do some scenery to make it fit into the family room...
Junior
Shop Teacher
Postby HomeRacingWorld » Sun Oct 28, 2012 8:10 am
I am ready to race on this one soon.
What a great track you made in the space you had to work with.
Return to The Lumber Yard
