Home Racing World • View topic - 1/32 Sportsman Galaxie
Forum rules
Open to ALL SCALES!
Re: 1/32 Sportsman Galaxie
Postby bdsharp » Thu Aug 03, 2017 2:43 pm
Bravo, ya done good! That UV glue worked great for an application that's almost impossible to clamp. I've resorted to a complex system of rubber bands and cut-off Q-Tips.
I'm making some progress with my Galaxie too, but as it will be my Showdown entry, it's way too soon for pictures.
bdsharp
Postby Wobble » Thu Aug 03, 2017 3:00 pm
Wow, that looks good enough to eat ... it's making my mouth water.
Wobble
Postby strangebrew » Thu Aug 03, 2017 5:03 pm
.....ZOOM.......... :dance:
strangebrew
Postby Broman62 » Thu Aug 03, 2017 6:44 pm
Awesome tips Harry...those decals really "POP" with those sanding techniques!!! Beautimus build and looks to be a great runner!! :auto-driving: :auto-driving:
Postby clivearmstrong74 » Thu Aug 03, 2017 10:42 pm
That is skill and art combined...super job, well done!!!! My next one might look like that....I wish
Clive
clivearmstrong74
Postby dge467 » Fri Aug 04, 2017 7:28 pm
Great tips Harry! Car came out great!
Postby HomeRacingWorld » Fri Aug 04, 2017 7:30 pm
Thanks guys, appreciate the kind words.
Postby dreinecke » Sat Aug 05, 2017 7:42 am
I dunno. I think it needs a solid testing session at the PDR...
Postby HomeRacingWorld » Sat Aug 05, 2017 7:43 am
Ok.
Postby TuscoTodd » Sun Aug 06, 2017 6:34 am
That is one SHARP looking machine!
Never thought about using one of those UV pens for glass - it looks like I have a reason to finally break down and order one as that look a WHOLE lot easier to do than to fight with trying not to cloud the glass!
(having to go back with Novus Plastic Polish to remove the haze is NOT fun!)
Thanks for sharing Harry!
Postby HomeRacingWorld » Sun Aug 06, 2017 11:39 am
You are welcome, glad it helped.
One of those things that just works. Like our ceramic honeycomb boards, Future, etc. Something out of nowhere that is perfect for the job. :)
Postby Cincyslots » Tue Feb 06, 2018 12:17 pm
Very nice work!!!
Bruce
Cincyslots
Postby TAMELESSTGR » Wed Oct 24, 2018 10:00 am
TAMELESSTGR
Postby HomeRacingWorld » Wed Oct 24, 2018 1:30 pm
Resin wheels are never a good idea.
You can cast re-pop them and MAYBE work for a front. I have never bothered. They will still need sanding and truing. Think lathe. You will break the hub every time trying to tighten the screws. Just FYI, many emails I get are how to remove a stripped set screw. Because they overtightened. This is on aluminum (Slot.it, MB, CB Design). You will crack them unless you are VERY, VERY careful.
Press on is no option. Too brittle. Crack again. Even using softer shore 65-55 like I use won't cut it.
And at the end of the day, what cost savings? Silicone isn't being given away. Neither the resin. And then YOUR TIME to even make the mold. I personally see no cost savings.
And not to be disrespectful, I understand the cost per wheel issue. But there is no shortcut for a quality wheel. All the precision axles, bushings/bearings, etc won't amount to hill of uneaten salad if you are running on egg shaped wheels.
Just my $1.25
Wheel inserts? Oh absolutely. Have casted quite a few. Easy to make and look great. Just depends on the design. A 5 bolt/floater? No problem. An intricate wire wheel such as classic F1? Uhhh, not so great results here.
Hope this helps.
