Home Racing World • View topic - Show your track! - 2017
SHOW YOUR SLOT CAR TRACK!
Re: Show your track! - 2017
Postby Z-carfan » Mon Dec 04, 2017 9:27 pm
My first routed track ever done in 2014 for the SLOP proxy that didn’t happen.
My copy of vtech’s cool apartment one lane test track. 2’ x 8’ circa 2015
My 4’ x 8’ oval with slight banking in the corners, this is in my shop so it’s great for car testing. EST 2017
Finally, this was where my 4’ x 16’ AFX four lane lived. I pulled the track the other night and will be building a 2 lane Bertrand ‘8’ style track with variable PS and Parma controllers. Coming soon..
Update 12/17/17
got my 'Bertrand' fig 8 running over the weekend, now I cna actually run some cars!!!
Postby Fitzy » Mon Dec 04, 2017 9:42 pm
This is My Carrera Digital Track
This Is My Next Track I have collected a couple hundred running feet for a four lane Monogram Track
Fitzy
Postby dge467 » Mon Dec 04, 2017 9:45 pm
Nice looking tracks!!
This is the Iron Wood track that has been around for some time. It has gotten around New England quite a bit!
Postby Junior » Mon Dec 04, 2017 10:23 pm
More of my tracks, past and present
This was my first track with the kids some 15-ish years ago. I had it in the crawl on a 4x9 table, my only regret is the table should have been 5x9. We had a blast with it.
This one is my current test track I have in my work room.
Junior
Shop Teacher
Postby waaytoomuchintothis » Mon Dec 04, 2017 10:34 pm
This is right up your alley, ain't it, Harry?
Postby HomeRacingWorld » Tue Dec 05, 2017 1:21 am
Oh yes sir, have seen this latest track. Mr. Urbas is quite skilled.
Postby bobbyraz49 » Tue Dec 05, 2017 6:23 am
bobbyraz49
Postby Howie654 » Tue Dec 05, 2017 6:43 am
Well here's mine Harry, first wood track I have ever routed, 22×12 copper taped, RC timing and lap counting.
Howie654
Postby Junior » Tue Dec 05, 2017 10:59 am
Junior
Shop Teacher
Postby strangebrew » Tue Dec 05, 2017 12:48 pm
..................Strangebrew Speedbowl................
5' x 11' Masonite on particle board high banked bull ring.
Built about 10 years ago. Hinged to fold against the wall with the help of 2 garage door springs.
Don't have much room in the basement........Gotta' get to the washer & dryer ya' know.
Outside walls are corrugated sign material, inside walls are some kind of plastic strip from the hardware store,
infield is cardboard covered with vinyl & green exterior carpet.
Home built lap counter, copper tape & I use a switchable (6v-6a - 12v-2a - 12v-6a) battery charger for power.
strangebrew
Postby gascarnut » Tue Dec 05, 2017 1:04 pm
Here's mine - Pebblestone Model Car Circuit, well-known among the Proxy racing fraternity;
gascarnut
Postby mattb » Tue Dec 05, 2017 1:17 pm
Lots of different tracks over the years, I now stay with plastic so I can change it or box it up! The overpass side is actually 3 different length straights while the under side is 2 lengths, so it is not a straight figure 8. This current track is 30" X 7". We run only 1/24 solid chassis, extended Womps, H&R, Parma FCR, Sprintsplus cut and extended, Dynamic inline, and brass brackets on brass plate. It's all flat track moderately banked and shaped as discussed in another thread. The power supply is one of the $40 9-12 volt ham radio power supplies from Ebay, 30 amps, it runs everything.
Fitzy you sure got a bunch of clean Monogram track. 'That looks as nice as any I have seen. I do have a bunch if you find you need some odd pieces. It is my favorite slot track.
mattb
Postby waaytoomuchintothis » Tue Dec 05, 2017 1:50 pm
How similar is that Mongram track to the old Riggens-Revell track from the 60s?
Postby FC47 » Tue Dec 05, 2017 4:52 pm
Thanks Harry for kicking this into gear, and everybody for posting.
Lot of food for thought and inspirational pictures.
Can't post pics with a phone here but, theres a 30ft Carrera two-lane oval here with 9ft? straights.
Planning to do a likely three lane wood road course, over this winter, will score and time it with RC.
Might try and weave Hi-rail trains with it....
FC47
Postby mattb » Tue Dec 05, 2017 7:39 pm
Monogram and Revell are the same dimensions, but connect in a different way. Both have deep slots and 3 1/2 inch lane spacing, Inner and outer curves are around and not impossible to find, same with aprons. They are a different color, Mono is kind of a grayish green looking color, Revell is dark gray and Riggen is black. I have seen guys mate Monogram straights to Revell straights so they could use the Revell banked turns, which are 4 inch lane spacing and use an entry track that spreads the lanes to 4 inch centers.
mattb
Return to Reader's Roads
Users browsing this forum: No registered users and 77 guests
