Home Racing World • View topic - 1/32 Revoslot Porsche
Postby Brumos RSR » Sun Sep 24, 2017 9:51 pm
It's quick, not finished and is a work of art. With tuning, softer rear tires, it should be on par with a tuned Slot It Group C. Very smooth and loads of potential for a PROXY car or club runner.
Highlights:
Fully assembled Aluminum 2 piece chassis floating center pod
3mm axles and wheel bearings
Aluminum motor mount and motor screws included
Brass spacers included
21,000 rpm 200cg of torque 130 can motor
Anodized guide holder
Comes with a wood guide and shallow guide
Challenges:
Firm rear tires lack grip on my plastic track.
Tires must be trued for best running as its bumpy without light truing
Flanged 3mm aluminum wheels ( need to find out where to get tires). Paul G to the red phone please
Unique size hex screws in between Slot It and NSR
Does not include adjustments for front ride height
Raised hex screws that protrude underneath the chassis
Brumos RSR
Re: 1/32 Revoslot Porsche
Postby Brumos RSR » Sun Sep 24, 2017 10:17 pm
Pic w the body. Silver paint awaits
Brumos RSR
Postby Radarek » Mon Sep 25, 2017 5:16 am
Looking good, very good
just ordered number 27.
:banana-dance:
Radarek
Postby scatman » Mon Sep 25, 2017 5:30 am
I received my two RTR, and both cars run well on my wood track. I didn’t have any problems with the rear tires. Plenty of grip, smooth, with some gear noise right out of the box. Added some lube to the gears and that took care of the noise. I recommend the cars.
scatman
Postby mikeinclover » Mon Sep 25, 2017 5:51 am
Should have them in stock today. Some are already sold out. Hopefully we will be getting more in soon.
Mike
mikeinclover
Postby Brumos RSR » Mon Sep 25, 2017 8:06 am
Brumos RSR
Postby DaveKennedy » Mon Sep 25, 2017 9:11 am
They've made the same (maybe mistake?) that Spirit did with not joining the rear left axle tower and the motor holder. With the Spirit cars with the same long can motor you got lots of hop on high grip tracks that was sort of fixed when Spirit changed their design (with the last few releases) and made the modification to stiffen up the chassis.
I'm wondering if this car will have the same hop or has the pod been made sufficiently stiff that it won't have this issue.
Postby SuperSlab » Mon Sep 25, 2017 9:31 am
SuperSlab
Postby Brumos RSR » Mon Sep 25, 2017 9:35 am
Brumos RSR
Postby mikeinclover » Mon Sep 25, 2017 9:48 am
I think the mistake they are making is that they are using 3 mm axle. It didn't work well for Scalextric. At least with a bearing holder you should be able to change them out if you like.
mikeinclover
Postby cj74 » Mon Sep 25, 2017 10:27 am
Disappointed to see no front axle adjustment. Probably won't stop me from giving one a try at some point.
cj74
Postby DaveKennedy » Mon Sep 25, 2017 11:22 am
Postby DaveKennedy » Mon Sep 25, 2017 11:24 am
"Highlights:
Fully assembled Aluminum 2 piece chassis floating center pod"
My mistake... details hidden from me in plain sight!
Postby HomeRacingWorld » Mon Sep 25, 2017 12:13 pm
Not for me, but excellent review. Thanks for taking the time sir.
Postby Dogsbody » Mon Sep 25, 2017 12:15 pm
Dogsbody
Users browsing this forum: No registered users and 148 guests
