Having coffee with it - DONE!
Re: Having coffee with it
Postby HomeRacingWorld » Sun Aug 06, 2017 5:47 pm
Ok, check! A man of your status needs no reservation of course. Your usual table will be cleared and filled with Slotburgers and BBQ with room for a setup block :)
Postby munter » Sun Aug 06, 2017 9:52 pm
Try main rails of .062" wire. If one length doesnt do it you can add another one, side by side.
munter
Postby Ky.Slot Racer » Sun Aug 06, 2017 10:23 pm
Guess I need some coffee, that`s nice !
Ky.Slot Racer
HRW Master Modeler
Postby dge467 » Mon Aug 07, 2017 7:10 pm
Looks great Harry!! I got to give the brass chassis build a try!
Postby HomeRacingWorld » Mon Aug 07, 2017 7:18 pm
Thanks, it came out pretty good in the shakedown runs.
All standard Showdown Series gear on this one. Piranha motor, 9/27 Slot.it.
Postby waaytoomuchintothis » Mon Aug 07, 2017 8:02 pm
...and silent gears, perfect bearing centers, run-in motor, low center of gravity, perfect tire profiles, stable guide, etc. Look out, guys. He's serious.
Postby HomeRacingWorld » Wed Aug 09, 2017 7:08 am
LOL, well Rob...the problem is that none of that amounts to a hill of beans with my driving "skill" :) All the rest of the guys that race here have the same, if not better precision AND they can drive. So being last is common for me, but now I can do it in style :)
Mounted the body using my regular old techniques. I shimmed the body from the underneath to get the ride height I wanted and then slipped in the plastic mounting plates, and glued in place.
Used Evergreen sheet plastic this time. 2MM thick. I tacked in with CA (SuperGlue) and then flowed more glue after it dried.
Just a slight amount of rake.
Now to prep the body and get my paint right.
More Joe will be mandatory for that. :auto-checkeredflag:
Postby btaylor » Wed Aug 09, 2017 8:30 am
Sweet looking ride Harry! That is one heck of a package you have there. looks like it will be a fun car to drive. I cant get over how clean your chassis' look when finished. I work to fast most times, and the end result shows it. Of course when I do slow down and pay attention to detail, they still don't come out as good as yours.
Postby HomeRacingWorld » Wed Aug 09, 2017 12:48 pm
Thanks guys. Paint. Yes. Well that's where things get ugly. Lol
Postby chappy » Thu Aug 10, 2017 8:32 am
Harry , that is looking great. The chassis build is to be admired , and the body placement gives that ready to race look to all comers.
Looking forward to the livery and finished set up.
Kudos
Postby HomeRacingWorld » Fri Aug 18, 2017 6:43 pm
Thanks guys - well a few more hours and countless cups of joe.
Had these decals for a long time and thought: "Why not"? Just a theme car as usual.
The General took ownership :) We had some fun tonight under the lights.
Re: Having coffee with it - DONE!
Postby strangebrew » Fri Aug 18, 2017 8:08 pm
Check out the SHINE on that faded paint job!!
.................Nice job......................
strangebrew
Postby TuscoTodd » Fri Aug 18, 2017 8:45 pm
NICE!!!!
:text-bravo:
Postby dreinecke » Fri Aug 18, 2017 10:19 pm
LOVE the way this thing turned out!
Postby MoparGreg » Sat Aug 19, 2017 6:36 am
Looks great. Excellent craftsmanship. Your chassis work is top notch! I really need to up my brass chass building!
MoparGreg
Users browsing this forum: No registered users and 39 guests
