D124 Ford GT arrives
Postby DaveKennedy » Mon Jun 26, 2017 9:42 am
The D124 Carrera Ford GT is now here and is shipping as of this morning. Also more of the 1/32 (evo and digital) arrived today too. Pix this afternoon.. on this thread of my 1/24 sample. And the sample I got of the new one we're making later this year too probably.
**edit for photo added**
1/24 and 1/32 for comparison
The new 1/24 GT coming later this year. It's orange and gray and white. The gray bits are going to be a challenge to the the exposure right on my photos I see. But here's a preview of it... not sure exactly arrival but yes... this year.
Re: D124 Ford GT arrives
Postby Cincyslots » Mon Jun 26, 2017 10:48 am
This post is an hour old. Why have we not all received text messages that it in??? LOL This is great news. I can't wait to see it.
Bruce
Cincyslots
Postby DaveKennedy » Mon Jun 26, 2017 11:38 am
Updated with pix.
Postby DaveKennedy » Mon Jun 26, 2017 12:45 pm
Also just to repeat this car just arrived today... so don't expect to see it today in stock at a dealer.
Postby Cincyslots » Wed Jun 28, 2017 7:22 am
DK,
Are these arriving alone or is there a container list you can share?
Thanks,
Bruce
Cincyslots
Postby DaveKennedy » Wed Jun 28, 2017 7:37 am
it was in that email I sent out the other day Bruce.. .only a few items, it was mostly battery op sets.
Postby Cincyslots » Wed Jun 28, 2017 8:26 am
hmm, no emails from you since 6/16. no worries. thanks for the reply.
Bruce
Cincyslots
Postby DaveKennedy » Wed Jun 28, 2017 10:49 am
Ok that's bad... resent it.
Postby Josh S » Tue Jul 04, 2017 6:57 pm
Anyone know what size PG tires fit on this car? Is it the same as the other modern Carrera GT 1/24 cars?
Josh S
Postby edmagner » Wed Jul 05, 2017 6:24 am
Should be same as the C7R - i'm using Cincyslots instead of PGT - his C7R tires fit the GT fine and trued up nicely.
edmagner
Postby 32lbking » Wed Jul 05, 2017 8:58 am
The C7 Corvette tires from PG [29148] do fit the 1/24 Ford GT. I measured the rims on both cars and the C7 wheel is about .1mm taller and the rib is about .1mm wider than the GT wheel [not much at all]. I put the PG tires on the GT wheel and they fit quite well. If you hold one wheel on the axle firmly and twist, the PG tire on the opposite wheel will turn ever so slightly on the rim. If glued there should be no issue at all. If you have a rim that needs to be trued a bit it might be an issue, but the wheels on my cars are pretty good.
Gotta give an attaboy to Carrera for this.Their wheels have gotten a lot better. Also, I have noticed that the newer 1/24 cars have almost no side to side axle play.
On the Ford GT that I have tested,I pulled the rear magnet and the car runs so good on my Carrera track with stock tires that I am not even going to change it to urethanes. Even I have a hard time getting it to deslot :D . I haven't ran the second car yet, and hopefully it will be as good the first. Also there are no front ride height issues with the 1/24 car. Definitely one of my best driving cars if not the best. Most of my other cars have PG urethanes.
Randy
32lbking
Postby Josh S » Wed Jul 05, 2017 9:24 am
Awesome. Thanks so much for the quick replies!
Josh S
Return to Slot Car News!
