1/32 Sportsman Galaxie
Forum rules
Open to ALL SCALES!
Re: 1/32 Sportsman Galaxie
Postby TuscoTodd » Mon Apr 10, 2017 7:39 pm
Great to see updates on this Harry! :D
Postby Ky.Slot Racer » Tue Apr 11, 2017 10:17 pm
Great looking hot rod Harry, however I was hoping you were casting in origanal form, was needing a couple stock looking bodys.
Ky.Slot Racer
HRW Master Modeler
Postby bdsharp » Fri Apr 14, 2017 6:42 pm
Happy to see this one almost there!
bdsharp
Postby RazorJon » Sat Apr 15, 2017 5:50 am
Wow, what a ton of work you have done, looking great :text-bravo:
Postby HomeRacingWorld » Wed Apr 19, 2017 2:49 pm
Thanks guys.
So very busy here getting ready for the big shindig, but finally the body production is coming.
Shapeshifter Resins finally creates a new Sportsman :)
Just an example of the mold.
Looking good so far.
This will do.
The master in back. Fresh baked mold ready for modeling.
Postby scatman » Wed Apr 19, 2017 3:15 pm
Outstanding! Can't wait to see the completed car.
scatman
Postby dreinecke » Wed Apr 19, 2017 4:31 pm
Well looky here! Seems like you've got this down pat. I can finally retire! Look for a large semi dropping off many molds and associated things soon!
Postby CrockettNZ » Wed Apr 19, 2017 8:49 pm
looking sweet Harry
CrockettNZ
Postby bdsharp » Thu Apr 20, 2017 9:10 am
Ooh, pretty! I really want one of those for my Showdown '18 entry.
bdsharp
Postby HomeRacingWorld » Mon Jul 17, 2017 7:42 pm
Well you should have one by now sir :)
Been too long since I had some time to build. Lame excuses abound, but finally back to it.
Just some shots of the chassis in progress. JK Bracket, brass and some piano wire is all.
Ran the wire inside the brass tubing and bent it up for added front axle support.
Made some "shaker" pans or sort of. They slide over the frame tubing (one size up) and do allow a little float.
The bottom plate and rod set the front to back motion. Since I am just experimenting, I cut the plate just a shy short so I threw in a rod.
Guide mount and side tunes for wire routing.
All done and painted with Duplicolor Gun Metal.
To be continued ;)
Postby bdsharp » Mon Jul 17, 2017 8:19 pm
Yes I do, and I'm working on getting it mated up to this. I miscalculated with the guide support and had to shorten it a little after these pictures. So far, so good.
bdsharp
Postby TuscoTodd » Mon Jul 17, 2017 8:36 pm
GREAT looking chassis build guys!
:text-bravo:
Postby HomeRacingWorld » Mon Jul 17, 2017 9:06 pm
Yes great work there BD. Really like that "Z" frame approach. Reminds me of my mod chassis. Really well done.
Postby bdsharp » Tue Jul 18, 2017 8:07 am
Thanks. This isn't Build-Off work, but I'm inching toward a Showdown '18 entry. Summer is easier than winter for me to work on it, and it takes me weeks if not months anyway. Harry's Galaxie body is really nice- very smooth inside and out, and looks like it will need only a minimum of work to prep it for paint. Get your hands on one while they last.
bdsharp
Postby bill from nh » Tue Jul 18, 2017 9:46 pm
BD, whose inline motor bracket are you using? I don't readily recognize it, is it one you made yourself or someone's production part? :)
bill from nh
Users browsing this forum: No registered users and 33 guests
