CARacing -1968 Karmann Ghia
Forum rules
Open to ALL SCALES!
Re: CARacing -1968 Karmann Ghia
Postby SLOTTING SINCE 1963 » Tue Feb 21, 2017 4:36 am
Clive, I like what I see..........
Nothing wrong with your PVC type chassis, but I'm keen to see your handy work in brass !!!!!!!!!!
Richard.
SLOTTING SINCE 1963
Postby BARC 1 » Tue Feb 21, 2017 7:11 am
That body turned out very nice. I am most impressed with what you have done from a block of wood.
Where are you getting your PVC material from?
Postby clivearmstrong74 » Tue Feb 21, 2017 10:55 pm
Thanx Dan!
The PVC is old menu panels from the take away restaurant within our outlet. Most advertising companies here use pvc sheets and stick vinyl on top for advertising boards. Local is lekker!
I will attach a pic.
Clive
clivearmstrong74
Postby clivearmstrong74 » Tue Feb 21, 2017 11:01 pm
PVC sheet with vinyl sticker, advertising board.
Clive
clivearmstrong74
Postby waaytoomuchintothis » Tue Feb 21, 2017 11:24 pm
Wow! That's some expensive chips! That's over $22.50 US! I take it you aren't in Australia, Clive! Where are you, dude?
Postby gsmea » Wed Feb 22, 2017 2:46 am
It is South Africa. The medium chips is R19.25 which equates to $1.47.
Clive, your Ghia is coming on nicely. Well done.
Gavin
gsmea
Postby clivearmstrong74 » Sun Mar 05, 2017 10:43 pm
Hallo everyone!
It has been two weeks of stock taking, month-end and lots of stufff....very little time to work on the Ghia, but here is a pic of the chassis and the body as it is now.
Chassis is rolling and it only needs a paint job to be completed. The body is 90% finished with only a couple of small fixes and then off to the paint bay.
Clive
clivearmstrong74
Postby gsmea » Mon Mar 06, 2017 11:03 am
Nice Job so far.
Gavin
gsmea
Postby clivearmstrong74 » Tue Mar 07, 2017 5:08 am
and we are finished with the body....now off to the paint booth. White top and red bottom...should look good.
Clive
clivearmstrong74
Postby BARC 1 » Tue Mar 07, 2017 8:17 am
Looking very nice.
Postby clivearmstrong74 » Sat Mar 11, 2017 10:33 pm
some more progress...the first layer of paint will show all the bad spots and more work to be done.
Clive
clivearmstrong74
Postby Brumos RSR » Sat Mar 11, 2017 11:55 pm
Clive, this is phenomenal.
Brumos RSR
Postby clivearmstrong74 » Sun Mar 19, 2017 12:09 pm
Some more work done over the past weekend...wish weekends were longer!! Hahah
Painting the body was in two parts, top colour is off-white and bottom we wanted candy apple red...I think we got it spot on...
The chassis was also finished and painted.
Clive
clivearmstrong74
Postby BARC 1 » Mon Mar 20, 2017 12:35 am
Sharp looking car
Postby gsmea » Mon Mar 20, 2017 4:43 am
I'm in love.....
Awesome work.
Gavin
gsmea
