Home Racing World • View topic - Worth it?
Worth it?
Worth it?
Postby btaylor » Sun Jan 08, 2017 5:22 am
Found these on the "bay" Looks like it might be good for personal use for setting up a series?
http://www.ebay.com/itm/401153729651?_t ... EBIDX%3AIT
Re: Worth it?
Postby buspor63 » Sun Jan 08, 2017 5:43 am
For me, It would look good on the shelf next to some other vintage slot stuff. However, I think I would use the optical RPM tool for ease.
buspor63
Re: Worth it?
Postby btaylor » Sun Jan 08, 2017 5:54 am
Re: Worth it?
Postby TuscoTodd » Sun Jan 08, 2017 7:47 am
Definitely not something you see every day. :)
Re: Worth it?
Postby HomeRacingWorld » Sun Jan 08, 2017 8:03 am
Re: Worth it?
Postby walker » Sun Jan 08, 2017 8:40 am
Mind that the max. rpm displayed are 3000. So you need something to reduce the rpm of the motor or axle you want to check.
A nice show item on the shelf, but for serious reading I would use a modern device - laser or IR.
I am fascinated by the shipping...
Roland
walker
Re: Worth it?
Postby Broman62 » Sun Jan 08, 2017 11:31 am
Cool vintage!!
Harry, is the one you "linked" the same as the one you posted in your tach set-up thread awhile back??
Re: Worth it?
Postby btaylor » Sun Jan 08, 2017 12:04 pm
Re: Worth it?
Postby HomeRacingWorld » Sun Jan 08, 2017 12:26 pm
Yes, same unit sir.
Re: Worth it?
Postby Broman62 » Sun Jan 08, 2017 4:48 pm
Thank you Harry!!
Re: Worth it?
Postby waaytoomuchintothis » Fri Jan 13, 2017 4:02 pm
Re: Worth it?
Postby waaytoomuchintothis » Fri Jan 13, 2017 8:01 pm
Bump for Bob Taylor to see.
Re: Worth it?
Postby TuscoTodd » Sat Jan 14, 2017 6:29 am
OK - that makes a little more sense (based on what is on the face) - thank you for sharing how it operates!
Re: Worth it?
Postby SpeedyNH » Sat Jan 14, 2017 7:24 pm
odd that it's actually a cumulative turns counter. I don't think that I've ever seen one of those. go figure.
SpeedyNH
Re: Worth it?
Postby waaytoomuchintothis » Sat Jan 14, 2017 7:46 pm
They went to some trouble making the side panels clear so you could see the gears spinning. The gears are all brass, nicely cut and sealed inside the body. There isn't even a lubrication hole anywhere on it. There are no instructions at all, and no explanation for the sawtooth edges of the base. It really is an oddity of the first order. The rubber band that holds a small bag of spare spring connectors on the base is one of those transparent natural rubber bands from Japan you used to see in the 1950s and 60s.
Return to SlotCar ToolTime
