Home Racing World • View topic - Easy windscreen tip!
Postby btaylor » Mon Jan 02, 2017 11:40 am
Had to share this one. I build a lot of Vintage style open wheel cars, and one of my biggest challenges is to mount a windscreen without glue marks or clouding :doh: . I came up with this for my midget builds, and thought it might help some of you F1 guys as well. Using a cut plastic sheet, I clamped it around the body where it will mount. I then heated a push pin to make holes through the windscreen and body.
I then took some Tapered toothpicks (round), and rolled the very tip in superglue. I pushed the taper in as far as it would go, and let dry. The taper tends to push the windscreen close to the body, and the glue bonds both screen and body. I cut the toothpicks off just proud of the windscreen, and used the same toothpick to dab a little silver paint to simulate a snap or rivet. easy as pie, and no glue marks! :clap: ImageImage Hope this helps someone!
Re: Easy windscreen tip!
Postby BARC 1 » Mon Jan 02, 2017 12:00 pm
Nice tip. I will use it.
Postby tjettom » Mon Jan 02, 2017 12:40 pm
Sir, What are the wheel /tire sizes and brand/ sources for them? They look the correct size!
Thanks,
Tom
tjettom
Postby btaylor » Mon Jan 02, 2017 1:08 pm
Postby loosewheel » Mon Jan 02, 2017 1:31 pm
Very clever tip! I've struggled with windscreen gluing for a long time.
loosewheel
Postby CrockettNZ » Mon Jan 02, 2017 1:44 pm
very nice tip
I will keep that in mind for next time
CrockettNZ
Postby strangebrew » Mon Jan 02, 2017 1:52 pm
I'm going to try that today. :P
strangebrew
Postby dge467 » Mon Jan 02, 2017 6:09 pm
That is a great tip! Looks great, as dose the rest of the car!
Postby Audi1 » Mon Jan 02, 2017 7:15 pm
Now that's pretty cool!
Postby Z-carfan » Tue Jan 03, 2017 9:29 am
Very cool idea!
Postby TuscoTodd » Tue Jan 03, 2017 7:33 pm
Bob - that is definitely a SLICK idea!
Thanks for sharing!
:text-bravo:
Return to The Slot Car Garage
Users browsing this forum: No registered users and 48 guests
