Home Racing World • View topic - Fly March Tuning
Fly March Tuning
Fly March Tuning
Postby HomeRacingWorld » Sun Dec 11, 2016 3:46 pm
Re: Fly March Tuning
Postby Abarth Mike » Sun Dec 11, 2016 8:30 pm
Does your mate Paul still make the lead radiators?
Seems like sacrilege to remove that beautiful "70's? bulbous F1 profile from the tires? :o
Abarth Mike
Postby HomeRacingWorld » Sun Dec 11, 2016 9:13 pm
Not even sure what that means.
Tires are very close to original size. If you don't care how it runs, then stick with high center/low contact tires.
Postby HomeRacingWorld » Sun Dec 11, 2016 9:14 pm
Postby munter » Mon Dec 12, 2016 12:33 am
Nice tuning article, Harry.
I have a Fly March...just one that I bring out sometimes. I know if I run it too much I will wreck it so it just gets the odd lap or two.
A while back I tried casting some tires. After doing some narrow ones I thought I would try something wide. These Fly March tires must be the widest 1/32 tire out there. I have done a few pairs now and have given a couple away but only used one set myself. I like alloy rims so I tried the Slotit F1 hubs...no good, too narrow so I looked around. I considered some of the CB design F1 hubs but as I was placing an order at Pendles I got something from there. These hubs are 14 x 14 and are still a tad too narrow. I glued and trued the tires and then fitted the wheels to a chassis I had sitting around for that final running in. The weight of the chassis and long can motor adds to the running in process.
I also used a hub and took a mould to make inserts. For some reason they are still not on the March.
munter
Postby HomeRacingWorld » Mon Dec 12, 2016 12:41 am
Nice work sir. The PG tires are very close to original size and I have been lucky being able to save the stock wheels.
HOWEVER, one car looks like it needs a rebuild and it might be time to get creative.
Thanks for the info.
Postby Dangermouse » Mon Dec 12, 2016 1:04 am
"Does your mate Paul still make the lead radiators?"
Someone - maybe Paul Gage made a mould of the side radiators and cast them in white metal - you removed the plastic ones and replaced with the metal ones to provide some weight at the rear
Can't find any reference to it on the net anymore
Dangermouse
Postby munter » Mon Dec 12, 2016 1:16 am
Gee, just noticed how raggy the inside face of my tires look...must give that a sand.
munter
Return to The Slot Car Garage
