Home Racing World • View topic - soldering
soldering
soldering
Postby davek » Thu Nov 17, 2016 12:28 pm
What brand solder,what dia. And where to buy please.Thank you. :flags-waveusa: :flags-waveusa: davek
davek
Re: soldering
Postby HomeRacingWorld » Thu Nov 17, 2016 1:49 pm
Re: soldering
Postby davek » Thu Nov 17, 2016 2:21 pm
Thank yo u Harry, do use rosin core for brass? Sorry I did not specify what is for. Sometimes I guess I expect people to read my mind, which usually is a blank page davek :flags-waveusa:
davek
Re: soldering
Postby gascarnut » Thu Nov 17, 2016 2:38 pm
For slot car frames, you will need to have an acid flux always. Yes, it is possible to solder brass to brass with rosin flux, but believe me it works better with acid flux, and any time there's piano wire involved, acid flux is a must..
The best acid flux IMO is Stay-Clean: http://www.harrisproductsgroup.com/en/P ... -Flux.aspx. It is available from many different places, in two or three sizes, so Google for the best price and delivery to your area.
As for solder, most 60/40 solders are fine, but for me, the extra strength from a 2% silver solder is worth it. I use this: https://www.radioshack.com/products/sil ... 0331827717 or this: https://www.radioshack.com/products/rad ... 0331574469 The difference is just the diameter of the wire. The smaller one helps with fine work to control how much solder is placed in the joint.
While you are ordering from Radio Shack, get some of this too: https://www.radioshack.com/products/rad ... 0331827077
This is a tip cleaner and tinner for your soldering iron. It works much better than a wet sponge and helps the tip last longer, especially when cleaned off using one of these: http://www.homedepot.com/p/Hakko-599B-S ... /204264881.
BTW, nice to see that Home Depot are stocking Hakko Soldering iron accessories now - they are super high quality. Just a pity they don't have the right irons for our needs. The best Hakko iron for scratch builders is the FX601, IMO.
gascarnut
Re: soldering
Postby SlotCarCorner » Thu Nov 17, 2016 3:04 pm
SlotCarCorner
Re: soldering
Postby davek » Thu Nov 17, 2016 3:33 pm
Thank you all so much for the info, I will look in to this. davek :flags-waveusa:
davek
Re: soldering
Postby waaytoomuchintothis » Thu Nov 17, 2016 3:47 pm
*Nothing you build is fast enough to require anything "extra strength"...
Evil, dude, just evil. But I am going to steal that line the next time anybody asks me about silver solder.
Also, Dave- you need to be aware that silver solder usually requires higher heat to flow properly, and the flux for silver solder has to be thoroughly washed off afterward to keep it from corroding everything it touched.
I use a Hakko that is older, but very similar to "FX-8801". http://www.all-spec.com/Catalog/Solderi ... AvFf8P8HAQ
Re: soldering
Postby Pappy » Thu Nov 17, 2016 3:55 pm
Pappy
Re: soldering
Postby HomeRacingWorld » Thu Nov 17, 2016 4:15 pm
Re: soldering
Postby davek » Fri Nov 18, 2016 7:24 am
I just received Circuit Specialist 75 watt iron,extra flux,10 tips, for$80.00 and free shipping from them. davek :flags-waveusa:
davek
Re: soldering
Postby gascarnut » Fri Nov 18, 2016 1:47 pm
gascarnut
Re: soldering
Postby SuperSlab » Fri Nov 18, 2016 5:19 pm
SuperSlab
Return to SlotCar ToolTime
Users browsing this forum: No registered users and 41 guests
