Home Racing World • View topic - Strombecker Porsche RS-61 1/32
Bring Back Some Memories!
Postby bookie » Fri Feb 20, 2015 3:30 pm
bookie
Re: Strombecker Porsche RS-61 1/32
Postby chrisguyw » Fri Feb 20, 2015 4:11 pm
Hi Rick, You could always glue the tires (or new ones ) to the existing wheels....the wheels do look really nice!
If you are set on replacing them with CB design, a 15 x 7 wheel will do the trick, and a set of 20/21 x 7 tires will work/look great.
I am sure that you are aware that you will need to change more than the axles to make the change to 3/32 set screw wheels.......you will need to replace the bushings, (single flanged 1/4 x 3/32) ,and you can either sleeve the current crown, or buy a new 3/32 sized crown.....if you use a "modern" crown (Slot-it etc.) you should change the pinion as well, as the stock one is likely a 48P pinion, and while it will work, it won't work well.
If you are trying to achieve a "vintage" look you can buy 15 x 7 wheels/ tires, and Porsche inserts from RSSlotracing..............the attached pic. is of a Strombecker RS 61 with RS wheels/inserts.
Chris Walker
chrisguyw
Postby bookie » Fri Feb 20, 2015 4:50 pm
Thanks for the information, I really do want to try and keep the wheels looking as stock as possible. Nice looking Porsche too!
bookie
Postby chrisguyw » Fri Feb 20, 2015 5:02 pm
chrisguyw
Postby Kuebakbo » Thu Sep 03, 2015 2:48 am
Here's what I'm searching for the most.
Kuebakbo
Postby chappy » Thu Sep 03, 2015 9:15 am
Nicely explained Chris.
And your Porsche is no slouch either.
Postby Mitch58 » Thu Sep 03, 2015 9:31 am
I just used the 15x7s that I had and they fit great.
Mitch58
Postby Quickcars » Thu Sep 03, 2015 12:43 pm
I think I have one of these that I've been working on forever! Love the body style and Strombecker did a nice job on this car.
Chris, your work continues to amaze. I love what you do with Ninco classics and that Strommie above looks amazing too.
Well done!
Here's a couple of pics of my humble effort. It's mounted on a "Sebring" chassis. Still needs work as I have the original super shallow guide that came with the chassis. It is useless. For the time being I just added a nice sheet of lead to the bottom and it's so heavy that it runs pretty well for now.
Paul
Quickcars
Postby chrisguyw » Thu Sep 03, 2015 1:26 pm
chrisguyw
Postby Quickcars » Sat Sep 05, 2015 4:47 am
Yes Chris, please post more pics of your Strommie rebuilds. I'd love to see them!!!!
Quickcars
Postby Nor Cal Mike » Sun Sep 06, 2015 8:09 am
They are indeed beautiful.
Nor Cal Mike
Return to Vintage Slot Cars
Users browsing this forum: No registered users and 59 guests
