Willys Modified
HO Scale Slot Car Forum
Willys Modified
Postby kcl » Sun Sep 09, 2012 6:32 am
Hi
I'm new to this forum, but my friend Larry Lype suggested I post
some builds over here, so I'll start with this
Started with a Willys body the hood is from sheet plastic and the bumpers
are made from paper clips. Decals are from Polecat.
Not made to represent an actual car, I just needed decals that worked
with the car.
Thanks for looking
Kevin
kcl
Re: Willys Modified
Postby hoganracing » Sun Sep 09, 2012 6:45 am
Kevin,
Welcome to HRW. Fine looking modified. Look forward to seeing more of your creations.
Patrick
hoganracing
Frequent Flyer
Re: Willys Modified
Postby FrankfromNY » Sun Sep 09, 2012 5:10 pm
Like that Willys.
FrankfromNY
Re: Willys Modified
Postby HomeRacingWorld » Sun Sep 09, 2012 5:41 pm
Great work indeed. You really added a lot of detail in this little hot rod.
I take it you made your own wheels?
Re: Willys Modified
Postby kcl » Sun Sep 09, 2012 5:53 pm
Actually those are old tyco-pro or HP2 wheels from the flip up
funny cars. Tyco used them on both. Used rear wheels front and back
and drilled them out to fit the axles.
Kevin
kcl
Re: Willys Modified
Postby HomeRacingWorld » Sun Sep 09, 2012 6:03 pm
Well THAT is scratchbuilding HO style fellas.
Thanks. Hope to see more of your work.
Re: Willys Modified
Postby RichD » Mon Sep 10, 2012 2:36 pm
That is a nice job. We often use Willys bodies as the basis for vintage modifieds. This one is on a T-Jet chassis that had the wheelbase stretched. I need to get bigger wheels and tires on the back!
Re: Willys Modified
Postby sirslotsalot » Tue Sep 11, 2012 8:55 pm
Kevin,
SWEEEEEETT!!!
sirslotsalot
Re: Willys Modified
Postby eeprof » Wed Sep 12, 2012 5:43 am
Nice job!!!!
eeprof
Re: Willys Modified
Postby BIG E » Fri Sep 28, 2012 6:38 pm
Very,very nice! Is that an A/FX type chassis is see under there? Also, are those the same wheels that TYCO used on the Pinto and Gremlin modifieds?
Really great work, I like the car a lot.
Hope ya win a bunch of races with it! Enjoy... Ernie
BIG E
Return to HRW HO Scale
Users browsing this forum: No registered users and 33 guests
