Vintage Crown Gear Source?
Bring Back Some Memories!
Postby Cartrax » Fri Nov 21, 2014 10:17 am
Anyone recommend a good source for vintage crown gears? Thanks.
Cartrax
Re: Vintage Crown Gear Source?
Postby DAVE » Fri Nov 21, 2014 3:44 pm
The current Parma 48 pitch crown gears are the old Cox crowns with a different color, and grade, of
plastic. I just color them with a sharpie. The Kemtron and K&B bevel gears that I used in the sixties
often show up at model car/slot car swap meets.
DAVE
Postby olskoolslotz » Fri Nov 21, 2014 8:48 pm
olskoolslotz
"THE Champ"
Postby Cartrax » Sat Nov 22, 2014 4:45 pm
Thanks for the replies guys.
Specifically - Looking for a couple of crowns for Strombeckers - these are for the older plastic chassis axles (D-type Jags and Testa Rossa's) I'm getting 1/8" diameter micrometer reading on the smooth part of the axle.
Others - I don't even know about yet - will be as the needs arise. Been buying vintage cars and refurbing "em. Really enjoying it especially when I can get "em turning lap times close to my newer stock.
Cartrax
Postby Xr4ti » Sat Nov 22, 2014 6:14 pm
You might try a 24T steel Revell.
That's what fits in my Testa Rosa with the open frame motor.
I've got one if you need it and probably Strombecker gears too.
Xr4ti
Postby BIG E » Wed Nov 26, 2014 1:49 pm
I believe COX and WELDUN gray crown gears are still available to hobby stores from REH Distributing in Cincinnati, Ohio.
Don't know for sure, it's been many years since I've placed an order with them. Check with your usual slot/hobby sources.
The PARMA ones are better -- but PINK! :>) Good luck... Ernie
BIG E
Re: Vintage Crown Gear Source? ANY LUCK?
Postby BIG E » Thu Jan 22, 2015 6:06 am
Just wondering... any success locating the gears you were looking for? -- Ernie
BIG E
Postby bill from nh » Fri Jan 23, 2015 9:10 pm
Should you not like the Parma pink, dye them another color using RIT fabric dye. Black & red both cover the pink well, but others, such as green, won't. It'll wear off where the teeth makes contact with a pinion, but you'll have a pretty looking gear. :lol:
bill from nh
Postby BIG E » Tue Jan 27, 2015 11:29 pm
Does the dying process affect the durability of the gears? -- Ernie
BIG E
Postby Ramcatlarry » Sun Apr 05, 2015 8:04 pm
Dying can be done several ways with nylon gears or electrical sockets. Dye in water alone in the microwave for a minute is the easiest. Add some oils and the plastic can be lubed a bit. plastic can be porous ....overcook and they can get brittle. redye if the color looks bad. Drag timing systems require a very opaque black (to infared) for flags
Ramcatlarry
Return to Vintage Slot Cars
Users browsing this forum: No registered users and 47 guests
