Almost Finished
Re: Almost Finished
Postby kcl » Wed Dec 30, 2015 6:12 pm
Construction continues on the Austin coach. Mounts for the body
are now installed. Body clips over the exsiting grear clamp and
just snaps on.
Hood has been fabricated with a small cowl piece added and started on the bumpers.
Car is starting to take shape. A few more pieces to do on the front, then on to the rear.
All for now
Kevin
kcl
Re: Almost Finished
Postby BRP32 » Wed Dec 30, 2015 7:13 pm
Awesome!!!!!
Just Awesome!!!!
Love the vintage fuel injection stack unit and the old dirt track sedan body is just great!!!
Thank you for sharing the build!!!
BRP32
Re: Almost Finished
Postby dreinecke » Wed Dec 30, 2015 9:20 pm
Kevin - as always, a HIGH quality build! I still love your metal work as always. The "football helmet face-guard" looks great!!! I am just amazed at what you get done!
Re: Almost Finished
Postby kcl » Sun Jan 10, 2016 11:07 am
Been working on the rear bumper of the coach. Starting to come together pretty good.
Most of the pieces are in place, but will need a little more clean up before finishing.
After this part is cleaned up, we'll add some uprights between the bars and add the
support bars for the body. Perhaps a piece in the back of the body to support it
would work better, we'll have to think on it.
All for now
Kevin
kcl
Re: Coach body
Postby Ralphthe3rd » Tue Jan 12, 2016 10:41 am
Kevin, your latest Coach body build (as well as all your builds), looks really sweet :text-bravo:
I'm looking forward to seeing this Vintage Modified Coach, detailed and painted up :)
Ralphthe3rd
Re: Almost Finished
Postby kcl » Sat Jan 23, 2016 10:22 am
The snow is falling and wind is blowing, good day to work on some bumpers for the coach.
We're putting the uprights in the rear bumper starting with cutting an small piece of clip
then grinding it to fit inside.
It just happens to be the width of the hemostat, after grinding the fit is checked and adjusted. Once
the fit is good the piece is then placed on a piece of plain old scotch tape and placed inside the bumper.
Once in place and adjusted, it's then glued at one point, and adjusted before the glue sets up.
Once set the tape is removed and glued at the other point. Use a small paper clip with some
glue and let it wick around the piece.
This is done for each piece. Got four in, have one more to go. After this all sets up it will be
scraped and sanded. Hopefully after finishing and paint, the inperfections don,t show.
Have much more to do on the car, but with the weather outside sure not going anywhere
so I will spend the day playing with this.
All for now
Kevin
kcl
Re: Almost Finished
Postby kcl » Sat Mar 05, 2016 12:09 pm
Work on the coach continues. The bumpers are done and the the body suports are installed.
Some extra pieces had to be put in to help keep the body supports in place.
Work on the cage has also started, going with a x brace this time. After this part is done we can continue building
around it. Notched the gear plate to mount it as the body is very skinny and needs the room
to get it on and off,
Injectors and filters are finished off and waiting for paint and cut the hole in the hood for them.
This will become the radiator after a little paint and some dry brushing over the screen to make it stand out
a little.
Doesn't look like much right now, but will all come together at some time.
All for now
Kevin
kcl
Re: Almost Finished
Postby kcl » Wed Mar 09, 2016 1:51 pm
Cage work is now complete on the coach.
X frame style with a couple of down tubes at the back to kinda fill in the back.
Works with the body quite well.
Sets back in the body along with the driver towards the rear. A little more cleanup on it and
the chassis should be ready for paint.
All for now
Kevin
kcl
Re: Almost Finished
Postby dreinecke » Wed Mar 09, 2016 10:41 pm
Kevin, I am as ever, blown away by your builds. Simply great work on this car!!!
Re: Almost Finished
Postby kcl » Thu Apr 21, 2016 5:56 pm
With all these roadsters and jalopys around here , thought I would try my hand at one.
Started with a hot rod body chopped the trunk off and built a new deck for it.
Chopped the hood and set it back to the rear hole in the chassis and set the body back some. Then cut the chassis in the front
to kinda look like frame rails and bobbed the rear.
Filled the sides of the hood in and opened up the grill. The front is cut in such a way that it
fits down into the frame.
Sanded everything up, made a roll bar for it and a header pipe. Going to be a 6 cylinder so one pipe. Assembled the car
to see what it was going to look like after some primer to check the body work.
Need to make a couple of stacks yet for the hood and figure out what color, but this is what I got so far.
More later
Kevin
kcl
Re: Almost Finished
Postby eastside johnny » Fri Apr 22, 2016 1:17 pm
I like how you opened up the nose. lOOks gOOd
eastside johnny
Re: Almost Finished
Postby SpeedyNH » Fri Apr 22, 2016 3:39 pm
Sir, you are a re-creational artist.
speedy
SpeedyNH
Re: Almost Finished
Postby vabchrog » Tue Apr 26, 2016 9:15 am
Ditto to that. his work is exceptional and always a joy to see.
vabchrog
Re: Almost Finished
Postby noddaz » Sat May 14, 2016 4:13 am
Just stumbled across this thread... You build fantastic little cars !
And thank you for sharing them with us!
Scott
noddaz
Re: Almost Finished
Postby TuscoTodd » Sat May 14, 2016 5:04 am
I missed this latest update when you posted it - WOW!
REALLY like the new project!
:text-bravo:
Users browsing this forum: No registered users and 87 guests
