Almost Finished
HO Scale Slot Car Forum
Re: Almost Finished
Postby legrandnormand » Sat Jun 21, 2014 7:44 pm
So many hours for this result... :|
legrandnormand
Re: Almost Finished
Postby TuscoTodd » Sat Jun 21, 2014 8:23 pm
That is pretty impressive! Looking forward to seeing how the final product shapes up! :D
Re: Almost Finished
Postby kcl » Sun Jul 06, 2014 8:54 am
The T-Bird is set aside for the moment as work continues
on the Falcon. A hood has been built along with a louvered
radiator cover.
Sanded a angle on the hood to give it a bent sheet metal look and
found some injectors for it so we will be building a box around
them. This is the beginning.
Glued all those pieces together into a box shape
After some cutting and sanding we have a fairly square box to work
with.
At this point, mocked everything up on the car to see what it would look
like. Needs some more work as it is a little high but that will be fixed
once mounted to the hood.
Still much work to do but it's coming along and starting to look like something.
More later
Kevin
kcl
Re: Almost Finished
Postby ChallengerGuy » Sun Jul 06, 2014 11:05 am
The Falcon is a fave of mine and your car looks great. With that armature gear so close to your stacks, it reminded me of the Matchbox "popper" car that had tiny red balls that popped up and down in the motor stacks as the car rolled...thanks for the pictorial and the memories! Ha.
ChallengerGuy
Re: Almost Finished
Postby red73mustang » Wed Jul 23, 2014 10:17 pm
Nice work Kevin, any chance that this Falcon will wear the Gerald Chamberlin # 76 livery ?
red73mustang
Re: Almost Finished
Postby kcl » Tue Aug 26, 2014 3:51 pm
Well I've gotten sidetracked again. While looking for some parts
for the Falcon,came across this 37 roadster body also a badly
mangled Willys. Took the top off the Willys and mated it to
the roadster to make a coupe out of it.
Did some more chopping and grinding on it and so far we have this
Body is very tight on the chassis so we made some mounts from an old
gear clamp and epoxied them into the body this will allow
mounting over the existing clamp.
Sits pretty good but a this rate I will never get the other two finished
keep getting sidetracked.
All for now
Kevin
kcl
Re: Almost Finished
Postby Austin » Tue Aug 26, 2014 4:22 pm
Kevin you are to much, your cars are wild. Now which cars do I have that I don't like. You are killing me. Thanks for all the posting I look forward to your posts
Austin
Re: Almost Finished
Postby kcl » Sun Sep 14, 2014 8:49 am
Work continues on the 37 coupe. We now have a hood
Also built a little piece to simulate a radiator and bent up a bar
with some nylon stocking glued on it to hopefully look like screen
when put in the car.
Neither of which can be installed till after paint.
Also started working on the bumpers.
Still a long ways to go but coming along. Front bumper needs to
be finished and sanded up then we can start on the rear.
All for now
Kevin
kcl
Re: Almost Finished
Postby dge467 » Sun Sep 14, 2014 6:05 pm
Nice details! Looking good!
Re: Almost Finished
Postby kcl » Sat Sep 27, 2014 6:54 pm
Front bumper is now complete.
Putting the little piece into the front between the bars
took a little doing but got it in there
So with that in,the front is ready to be cleaned and sanded
up.
The frame work for the rear bumper has been started and
work on the bumper will begin.
Have not come up with a final bumper style yet, but have to clean up
the frame work first as it will be easier to sand up.
All for now
Kevin
kcl
Re: Almost Finished
Postby kcl » Tue Sep 30, 2014 4:43 pm
The rear bumper is now complete and mounted on it's
frame work.
Reassembled the car temporarily to make sure everything fit.
Fit is good and it's even straight. That completes the chassis
now we can get on to other things.
More later
Kevin
kcl
Re: Almost Finished
Postby kcl » Mon Oct 13, 2014 5:42 pm
Started on the cage for the 37. The fit on this body is very tight
so some consessions had to be made. Started by notching the
gear plate and mounting the first u bend in them
Then built a old style x frame into it.
It looks better now after some more filler was added between the x's.
The rest of the cage is kinda old school. Just a front u with two bars
connecting the the front and rear.
Cage is based off a picture I found of just the cage and frame.
Although not as tall as I would have liked, if it was any higher I could not get
the body on. Sanding and clean up of all the joints will follow along with
the driver.
All for now
Kevin
kcl
Re: Almost Finished
Postby Austin » Mon Oct 13, 2014 5:57 pm
Kevin your cars look so real, love the work you do.
Austin
Re: Almost Finished
Postby TuscoTodd » Mon Oct 13, 2014 6:50 pm
That is AWESOME!
Are you using polished stainless wire for the cage or ?
:text-bravo:
Re: Almost Finished
Postby Ralphthe3rd » Tue Oct 14, 2014 8:29 am
FYI- he simply uses Cut-up paperclips Super Glued together, for his Cage and Bar work.
Ralphthe3rd
Return to HRW HO Scale
