Mega G+ Motor Break In?
Postby rcheli » Wed Feb 14, 2018 11:16 am
What is the preferred method for breaking in for the motor on a G+?
rcheli
Re: Mega G+ Motor Break In?
Postby Z-carfan » Wed Feb 14, 2018 4:05 pm
RC<
I wondered about this and found this note on another forum.
"Does the set have the new Mega G+ cars with can style motors? With any car that has an inline motor it does not hurt to break in the motor on the bench at 6 volts for 15-30 minutes before you put the car on the track. Dust from the brushes can get caught in the commutator slots and cause a short, it is best to flush the commutator with spray contact cleaner and oil the bearings before you run the car on the track."
I actually had not tried this on mine, I only have one MegaG+, however have fdone a similar breakin on my older Mega G cars. Hope that helps.
Postby rcheli » Wed Feb 14, 2018 4:17 pm
The only way I have to break in is on the track. Unless I can build a 'break in stand'. Not seeing much out there.
rcheli
Postby rcheli » Wed Feb 14, 2018 4:50 pm
Look like I'll actually start with a 13 foot x 3 foot oval, then go from there. Will eventually mount to 2 hollow door cores with felt and ground covering that separates and have handles for easy moving. Lots of ideas on scaling out the track and infield. 13 feet should wind'em up pretty good. Track will be 24 volts. Higher than the stock power supply. Cars are AFX Meg G Plus, newest AFX controllers. Fairly cheap to get going. Lots to learn. More technical than I thought which is a good thing. Always room for a little more power....
rcheli
Postby model murdering » Wed Feb 14, 2018 6:37 pm
Here's what the comm-plate looks like for the AFX mini-can. Brushes are your basic copper carbon unit, so they break in relatively easy. They are not pre-shaped to conform to the commutator, so a good break in is critical for optimum performance and longevity. The flat faced brush is nowhere near ready to transfer full current properly to the commutator under a load. Hence the conventional wisdom regarding break-in for the Mega G+
Look at all that wire! The Mega Gee+ is a fairly docile 17 ohm wind with benevolent magnets; all designed so lil Johnny wont burn his "finners", yet providing a nice long, very useable, mid range band, as lil motors go. The side view reveals that the pole bundles at shaft end of the armature are tamped flat at the factory, presumably so they dont rub the inside of the can. Notably in comparison, the comm ends sport a nice parabolic loop. I've only had two apart, but it is a bit odd.
If the chassis is dead new out of the package, start by finger rolling the chassis back and forth to scrape any oxidation off the commutator, so you get a good "first-start" when you apply voltage. I try to never cold start a motor/chassis that has been sitting. Pop the rear axle out carefully so there will be no motor load. Oil the shaft end LIGHTLY with a needle oiler. The comm plate end has a dust shutter, so it cant be lubed without modifying the shutter. Mount or stabilize the chassis in a clamp, so that you can hear only the motor; and not any of the weird harmonics or clattering vibrations that occur, when you run a chassis loose on the bench.
You'll need to regulate power, so you can start out at lower voltage. I use an ancient wheel controller with leads and small gator clips.
The motor should be run at 0 to 1/4 throttle. Just enough so that it lopes along smoothly. I usually occupy myself with other tasks at the bench, but keep and ear tuned to the motor and poke it with a finger to get a read on how much heat is being made. For other high ohm zoopy motors with black hole magnets, that like to heat up a bit, there's absolutely no reason you can beg off and continue when things cool down, assuming you've checked for any latent friction issues.
As the brushes begin to seat, you'll hear the tune change as the motor picks up RPM, and or smooths out. When things clean up you'll reach a plateau, where there is no change. Ease the throttle up to half, and let her chew on that a while. Same deal, keep your ears alert and poke it for heat once in a while. Repeat at 3/4 throttle as well.
From 3/4 throttle on up, I like to put the axle back in; so the motor has a load. Creep up on full throttle carefully. Keep in mind that an H0 chassis can fling it's tires at high RPM and shoot them across the room. Excessive pee winding of the motor/chassis serves no useful purpose. It's best to finish up on the track, maintaining a medium steady lap speed, and then bringing max throttle in gradually for the straights and sweepers.
Some guys like to provide or adhere to a specific time/hrs on the break-in block and walk away. I'm more of a believer in "ears on"; because not all brushes are created equally, nor are all commutators.
Good luck!
Last edited by model murdering on Wed Feb 14, 2018 8:33 pm, edited 1 time in total.
model murdering
Postby rcheli » Wed Feb 14, 2018 7:14 pm
Outstanding. Exactly what I was looking for.
What about dipping motor after break water and alcohol?
rcheli
Postby model murdering » Wed Feb 14, 2018 10:12 pm
I wouldnt. It's non-ventilated save for the the un-used mount holes and the drain hole on the shaft end. My sense of it is that you'd be hard pressed to get one dry because you cant blow throw it, only in one end and out the same end in a circuitous fashion that never really gets anything particularly dry.
It's further compounded by the fact that the whole mess ... motor, rf board, and pick up hangers are all soldered together as an annoying module to keep Johnny from sticking it up his nose via his ear. Meaning that you'd have to break the whole chassis down get access to the holes.
Congress and AFX didnt do Uncle John any favors on this one. :|
model murdering
Postby rcheli » Thu Feb 15, 2018 9:38 am
Gotcha. Thanks
rcheli
