Dodge L 700 Ramp Truck
HO Scale Slot Car Forum
Postby dge467 » Sun Jan 07, 2018 10:16 pm
This started out as a Tyco HO railroad accessory truck. I cut the cab from the chassis and then removed a section of the body behind the rear wheels to match the actual truck. I added the flaring and step plates to match the real truck also. I then painted it blue and white and added some emergency lights to the roof. The plastic ramp body is from a Hot Wheels die cast. Details on the ramp body were picked out with some paint. The rear fenders were used from the truck, I cut them from the chassis and glued them to the ramp body. The cab and ramp body were glued to a piece of sheet plastic. Some mounting posts were made from some plastic tubing. It is all mounted on a T-Jet chassis with original Aurora truck wheels. The front bumper and fuel tanks are from die cast cars and trucks.
Re: Dodge L 700 Ramp Truck
Postby vins123 » Sun Jan 07, 2018 10:21 pm
vins123
Postby Norman » Mon Jan 08, 2018 4:10 pm
That truck looks like it came right from the Aurora factory in 1963!
Great job, Sir! :text-bravo:
Norman
Postby dge467 » Mon Jan 08, 2018 5:42 pm
Hey thanks guys!
Postby GASSERMAN » Mon Jan 08, 2018 7:31 pm
Good professional job. I like it. Bob.................
GASSERMAN
Return to HRW HO Scale
