Without taking your car apart, it is difficult to fully diagnose a problem. I did notice your car was not balanced. You have a good amount of up and down movement on one side of the front end while the other side has little. When I put the car on the scales I see one side of the front end carries little to no weight.
Also, you have a good amount of play in your rear axle. Both side to side and overall. I'm thinking you didn't glue your bushings in or you axle is worn or something else....
Sent from my SM-G955U using Tapatalk
