Home Racing World • View topic - Small 1/24 cars
Small 1/24 cars
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Small 1/24 cars
Postby noddaz » Tue Aug 20, 2019 9:32 am
Has anyone run or built small 1/24 cars? Kind of the idea BRM has but done at home?
noddaz
Re: Small 1/24 cars
Postby WB2 » Tue Aug 20, 2019 10:06 am
No, but my interest has been piqued.
The last Slot Car Mods had an article about using Slot It running gear under a Tamiya Mini Cooper. Volume 4, Number 2.
Amato has printed chassis for Mini, Escort, and Rabbit models.
https://www.slotforum.com/forums/index. ... pic=166482
https://www.slotforum.com/forums/index. ... pic=166474
WB2
Re: Small 1/24 cars
Postby FC47 » Tue Aug 20, 2019 10:42 am
I’ve printed a Datsun 510....I may pod it....
FC47
Re: Small 1/24 cars
Postby noddaz » Tue Aug 20, 2019 4:57 pm
noddaz
Re: Small 1/24 cars
Postby VTECFOUR » Tue Aug 20, 2019 9:48 pm
Have built a VW Golf Gr.2, Datsun 240Z, VW Scirroco, Lotus Super 7 and Austin Mini Cooper S.
Check out this forum's 1/25 & 1/24 Scale Showcase in the Marty Stanley Scratchbuilders Showcase section showing my builds.
viewforum.php?f=45
I like building them as I can use most of the same mechanical parts that I use for my 1/32 cars.
P.S. I've got a Tamiya Honda S800 Racer kit on the shelf for a conversion this fall.
VTECFOUR
Re: Small 1/24 cars
Postby Wobble » Wed Aug 21, 2019 12:41 am
Amato also does a chassis for the Tamiya MX5/Miata (original NA model) and I must pull finger and get a couple. The Tamiya MX5 body is about the same length as a Scalextric or Pioneer Dodge Charger and 7-8mm wider.
Wobble
Re: Small 1/24 cars
Postby munter » Thu Aug 22, 2019 2:10 am
I would like to try the George Turner Mini in 1/24 scale....but as yet have not done so.
The kit comes with a resin chassis but requires a slotit pod for motor and transmission.
Always liked Minis and have owned a couple in the past.
Return to HRW 1/24 Scale
