Home Racing World • View topic - 1/24 brass chassis
1/24 brass chassis
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Re: 1/24 brass chassis
Postby BARC 1 » Tue Sep 11, 2018 7:09 pm
Postby BIG E » Fri Sep 14, 2018 1:25 pm
Score! -- Ernie :>)
BIG E
Postby waaytoomuchintothis » Sat Sep 15, 2018 1:57 pm
Believe me, there's no such thing as a "permanent" solder joint. HRW has numerous topics and instructions about soldering. Easy to find. The better your equipment, the better you are at soldering, in the most practical terms, though years of experience will equal fine equipment eventually, so just seek the good stuff and save time. You can't use too much flux is another axiom to learn. Solder will flow uphill with enough flux on cleaned up material. Also, its better to be too hot than not hot enough.
Postby Fathead59 » Mon Sep 17, 2018 1:21 am
It is only at the idea phase right now , different ideas , I was always of the mind that the only stupid question is the one not asked , so if anyone has done what I am going to be trying to do and has failed than please tell me not to do it. But if I am able to do what I think I can do I will let the rest of the slot car community know.
Fathead59
Return to HRW 1/24 Scale
