Home Racing World • View topic - H&R Racing Chassis
H&R Racing Chassis
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
H&R Racing Chassis
Postby Broman62 » Mon Nov 27, 2017 3:54 pm
A member just asked what an H&R chassis is so I thought I’d post this for him and maybe some newer members here:
A 1/24-25 scale adjustable chassis that is excellent for using with 1/24-25 scale model cars, resin bodies or whatever type body you want to use. You can use many type of motors, gears, tires, wheel, etc. combinations on this and can be purchased from many of our suppliers here on our forum.
This is just H&R Racing site to see what’s out there:
http://www.hnrracing.com/
Re: H&R Racing Chassis
Postby historiceng » Mon Nov 27, 2017 4:17 pm
Thank you very much, I felt a bit useless not knowing and appreciate your time. It looks like an excellent site.
I had seen the reference come up a few times and wondered if it was to do with Home Racing World..
Thank you for taking the time. :)
historiceng
Postby Racie35 » Fri Dec 08, 2017 8:40 am
Does anyone know if there's a Paul Gage tire for the hr chassis wheels? I think these are 27 mm tall so a little les wouldn't hurt either....I can't tell on the chart because they list 1/24 by car brand...xpgs would be nice
Racie35
Postby Z-carfan » Fri Dec 08, 2017 9:13 am
There are on ebay for sure. I searched for Paul Gage 1/24 H&R and found some. There are several sizes on his 1/24 urethane tires.
Or on SCC web site there are a list of the 1/24 tires they carry.
https://www.slotcarcorner.com/Paul-Gage ... -H-R-c339/
You will want to check your current rims and see if you have the ribbed or ribless wheels and your dimensions width and height to order the proper tires.
Postby Racie35 » Fri Dec 08, 2017 10:23 am
Thankyou....now if I can tell if it's a wide rib or narrow I'd know.. maybe wide rib tire would fit both?
Racie35
Postby HomeRacingWorld » Fri Dec 08, 2017 10:29 am
Postby Racie35 » Fri Dec 08, 2017 12:32 pm
Thanks Harry
Racie35
Postby historiceng » Fri Dec 08, 2017 12:43 pm
Thanks Harry, helps for me for future.
historiceng
Postby mattb » Fri Dec 08, 2017 12:53 pm
You can buy H&R chassis with silicone tires and you won't need to look for aftermarket tires.
mattb
Postby Racie35 » Fri Dec 08, 2017 1:19 pm
I have the wheels on another project...so I wondered...I gotta find out which rib this is..narrow or wide
Racie35
Postby Broman62 » Sat Dec 09, 2017 1:05 pm
Postby Racie35 » Sun Dec 10, 2017 11:54 pm
Thankyou....they're wide ribbed rears for sure....now I'll get the right one from pg cuz its lower....thanks again.
Racie35
Return to HRW 1/24 Scale
