A while ago I picked up a well used Strombecker Porsche RS 61. The body was in good shape, but was missing driver head(s) and any kind of windscreen. I did a fantasy livery (the rocker panel PORSCHE logo decal being something not to be seen in real life for a few years). For inserts I used some leftover steel look alike rims that either came with this car or some other car as spare parts (I really can`t remember). In any case, I do remember that I had some problems turning the rims down for inserts - the walls became quite thin as I approached the proper diameter.
Original restoration (circa July 2018)
Fast forward to present day and a chance to seriously prepare this car for running in a one-off race at a local home wood track made me have a second look at the original inserts. A search of the `net showed me that the real wheels were quite different from what I had - there were 10 holes - not 8, and the part of the rim where the holes were was not flat, but rather conical and rounded. Also the center of the wheel is made up of (I assume) interchangeable plates that were bolted to the rim using 5 bolts but then allowed the wheel to be single nut mounted on the axle, for more speedy pit stops.
So off to TinkerCAD I went and after a few hours and 3 or 4 revisions I came up with this...
Less than an hour later I had this...
Upper left - straight off the 3D printer, upper right - cleaned up the stringies and sanded the outer radius down to fit CBD 15`` insert wheel, lower left and right - painted.
See next post for how they look on the car (still haven`t figured out how to get more than 3 pictures into a single post here on HRW).
Peter
