Page 2 of 2
Re: Sprite Proxy Race 2018 -JT’s Build
Thu Jan 11, 2018 9:35 pm
by JT Previa
Thanks Dan. Thankfully, I don’t have time for scallops, because the last scallops I painted were a masking disaster
☠️. I’m thinking it’s time for the outlaw to return.
JT
Sat Jan 13, 2018 1:43 pm
by JT Previa
Almost everything except a pinion and some paint!
Sat Jan 13, 2018 2:08 pm
by VTECFOUR
Hi JT,
Have you filled those floppy outrigger tubes with lead or is that solid rod?
Sat Jan 13, 2018 4:18 pm
by JT Previa
The outriggers are solid .093 rods. The floppy outriggers also slide forward and backward trombone style: forward under braking to load the front and rearward under acceleration for traction. Did some tuning at Methe’s this morning - thanks Bob! Reduced tire dia , retrued Tires, changed guides, tried vaqrious weight additions and gearing options. Even managed to break a solder joint. Getting there.
JT
Sun Jan 14, 2018 9:21 pm
by JT Previa
Today I learned that the Tamiya British Racing Green is not dark green as the color of the cap, but nearly Kelly Green (Irish Racing Green?) So, out came the satin black and after the first coat, a sort of Green Hornet color scheme...which will not stay.
JT
Tue Jan 16, 2018 8:07 pm
by brainslot
Looking good JT. I might beat you at least to the Post Office...I'm going out in the blinding snow tomorrow to ship. Did you use a big foam block to mount the chassis to the body? I like the sliding weight idea. My first excursion into racing with the Shoreline guys decades ago...I built a Scaley Nascar that had slick sliding blocks on the chassis with the same concept in mind. However back then I also did not know all the other crucial aspects to setting up a car...so ah did not win any prizes against that competition.
Brian
Fri Jan 19, 2018 8:42 pm
by JT Previa
Yes, body mounted to via two dense foam block “posts” epoxied to the body. Blocks have threaded brass inserts epoxied into them. Foam is very light and dampens body roll. Trombone rattle pan is fun, hopefully effective.
JT
Sat Jan 20, 2018 12:52 pm
by JT Previa
Sanded out to 4000 grit:
Foiled again:
Maybe.
Sun Jan 28, 2018 3:31 pm
by JT Previa
Sun Jan 28, 2018 3:35 pm
by JT Previa
Some more photos from last week:
JT
Mon Jan 29, 2018 9:27 am
by brainslot
Nice JT. Inventive styling. What goes in the 'passenger' opening?
Brian
Mon Jan 29, 2018 1:20 pm
by JT Previa
Mon Jan 29, 2018 6:28 pm
by VTECFOUR
Nice vintage look in the tradition of your 1:32 builds.
Likely to be postmarked after January 19th, so penalty points will be assessed. Sorry, but I know you understand.
Looking forward to seeing and running it.
Wed Jan 31, 2018 1:04 pm
by RS Slot Racing
Hi Dan,
Any sign of my car arriving from the UK yet??
Posted on 16th Jan, International signed.
Col.
