Sprite Proxy Race 2018 -JT’s Build
Postby JT Previa » Tue Oct 31, 2017 8:44 pm
I just received my Slot Car Corner order for the miscellaneous parts I needed to complete my Sprite, so it was time to start building - or at least planning!
I started at SCCs Proxy Part Page, which has links to some of the typical parts needed to finish the kit.
JT Previa
Re: Sprite Proxy Race 2018 -JT’s Build
Postby JT Previa » Tue Oct 31, 2017 9:01 pm
Since I can’t seem to find the adjustable PCS chassis I was planning on using, I figur d I’d use up some of that brass and piano wire I’ve been accumulating.
I grabbed an index card and traced the top and side views of the chassis, paying particular attention to the wheel wells. I established a center line and then worked out where the axle center lines were.
Then, I turned my attention to motor mount options. It was clear a sidewinder was out...
The first option was to check to see how a Slot It pod would work.
It didn’t: very close, but those wheels aren’t fitting under the wheelwells. No room for s chassis extension to the rear (I’ve gotten around that on some Cheetahs I built, but...
So, I rummaged around and found a heavy duty BWA motor bracket. More scrounging found some oilier bushings that fit the holes. It good to be a hoarder !
Back end is shaping up, now to figure out how to deal with the Sprites notoriously tight front end....
JT Previa
Postby JT Previa » Tue Oct 31, 2017 9:07 pm
In order to work out some of the front end details, I consulted with some “experts” I had on the shelf...
JT Previa
Postby VTECFOUR » Tue Oct 31, 2017 11:57 pm
Aaah, the rat Bugeye #13 that was the inspiration for my scratch building and involvement in co-organizing proxies.
Good to see it and your later Bugeye entries in the 2013 and 2014 Sprite Proxy Races (SPR).
http://www.slotcarillustrated.com/porta ... .php?f=218
I've come a long way, but you were already doing wire and brass builds back then.
Looking forward to seeing your newest build.
VTECFOUR
Postby JT Previa » Wed Nov 01, 2017 11:49 am
Thanks, Dan. Having the kit parts certainly makes it easier to get started.
(My body has one side panel with a slight tumbledown inward. Is a cup of hot water the preferred way to soften the resin to reshape it?)
Back to that compact Sprite front end. I want to incorporate SCC axle blocks, because a level race car is a good handling car. I had used the axle blocks on my SPX Sprite, so flipped it over for comparison. While the widened SPX Sprite is close to the 1/29 Sprite’s width, the 1/29 front tire’s are much wider than the SPXs narrow ones. As a result, it will be tough to mount the axle blocks and still allow the nearly 180 degree guide rotation I prefer.
JT Previa
Postby JT Previa » Wed Nov 01, 2017 11:58 am
A few photos of body on wheels. Track will need to be a bit narrower to give some clearance between tire and body.
JT Previa
Postby JT Previa » Sun Dec 24, 2017 8:47 pm
Figuring out tire dia based on motor mount depth, clearance, and then converting to metric to compare to rules min tire diameter.
Main rails in place with sketch of planned chassis above.
JT
JT Previa
Postby JT Previa » Sun Dec 24, 2017 9:16 pm
Lots of wire bending and some hole drilling. Speaking of drilling, I need to pot some lateral hold downs on this jig like I added to my Retro Jig.
Did a bit more tire work on the Econo-Hudy. (I pulled a Tom Sawyer on my friend Methe, who insisted on showing me how the pros glue and true tires - sorry you got black tire superglue all over your hands Bob, I’m sure it will wear off....eventually.)
JT
JT Previa
Postby brainslot » Wed Dec 27, 2017 12:37 pm
Ah JT.....you are turning, tuning up the wick!. I knew if you could hide in the basement for a couple of days you would create something unique and well designed!
Brian :clap:
brainslot
Postby 73emgee » Wed Dec 27, 2017 2:31 pm
WOW!!! :scared-eek:
73emgee
Postby VTECFOUR » Wed Dec 27, 2017 4:37 pm
Whoa, a few bends on that outrigger wire.
Just JT being creative as usual.
Can hardly wait to see the box it comes in!
VTECFOUR
Postby JT Previa » Tue Jan 09, 2018 5:21 am
I’ve been in the basement so long, I’m just catching up to these responses . Thanks.
Yes, some impulsive wire bending, hopefully it’s functional!
JT Previa
Postby JT Previa » Tue Jan 09, 2018 5:25 am
The rare D-type Sprite.
I am falling in love with balsa wood.
JT
JT Previa
Postby JT Previa » Thu Jan 11, 2018 1:10 pm
Drillium to lighten up the brass mass and look cool.
I need to solder more often than once a year:
Polished up a bit. Jail door rattle pan doesn’t rattle as much due to some motor interference. Who designed this chassis!?
JT
JT Previa
Postby VTECFOUR » Thu Jan 11, 2018 3:16 pm
Well done on the aero look.
I can envision a paint scheme with scallops if you've got time.
Looking forward to seeing it.
VTECFOUR
Return to Sprite Proxy Race (SPR) 2018
