Re: What's on your bench right now? [1/43]
Postby taskak » Fri Apr 12, 2019 1:26 pm
taskak
Postby pfuetze » Sun Apr 14, 2019 6:35 am
nice paint job on the truck, Aki!!!
had the idea of drilling a hole, too, but Rolands method is way easier.
gear slip seems to be a major problem on the china gears. maybe caused by material?
gear slipped on the Lotus Exige that i´m building right now and also on the 356 Porsche. Porsche even got a mild motor (boxer) and long gearing, gear slipped anyhow. fixed with slots in axle and gear, copper wire and CA glue. i do not know if i will be able to remove that axle again. cutting the gear off will be the only solution maybe.
new controllers with brakes? great addition to the actual driving i guess!
i had to repair the cable on my 45 ohm Parma Eco controller yesterday. Cables seem the only weak point on them. but it´s an easy change/repair.
nice paint jobs on the driver figures!
Postby taskak » Wed Apr 17, 2019 9:03 am
taskak
Postby taskak » Sun Apr 21, 2019 11:59 am
taskak
Postby FC47 » Sun Apr 21, 2019 1:23 pm
Those are great!, all of my hobbies are so diverse I can't think of hitting another scale,
til maybe I completely retire....
But, I never miss a post in this thread to see what really great 43 :text-coolphotos: stuff you all are on to!
:banana-dance:
FC47
Postby taskak » Sun Apr 21, 2019 1:43 pm
taskak
Postby FC47 » Sun Apr 21, 2019 1:51 pm
Complete torture Aki, they all look great!
FC47
Postby pfuetze » Mon Apr 22, 2019 2:34 am
nice work on the Ferrari, Aki!
i did a little tuning work on the vac-formed Exige yesterday, making the gears run smooth and a little trueing of the rear tires. it runs really nice, looking forward to run it under race conditions when the grip level rises to that insane level where all those little inaccuracies start to show that you will never find in cruising mode on a little dusty track.
Postby pfuetze » Mon Apr 22, 2019 4:32 am
painted driver head and tray for the 356 Porsche.
waiting for the wheel insert to arrive, than it can be finished. chassis will need a little weight, due to the narrow track it has a tendency to barrel roll when goint into the corners too fast.
searching for the right wheel inserts for the Rambler Marlin, in some way the wheels do not look correct on this car. will try inserts ...
and the vac-formed Chevrolet Astro needed new tires on the rear, one old one melted away.
also played around with the setup of the car.
the wheel base is really short and the distance from the guide to the front axle is short, too.
in combination with no weight at all, the short gearing gave it a very tricky driving.
i ended up with adding weight, fishing tackle putty, 5g on each side of the motor, a total of 10g. Driving was better, but still not totally right. unplugged the brakes - this did the trick.
now it´s fun to run it aroung the track. did not time it, but now it is fun to run.
maybe will do the same to the Rambler.
Postby pfuetze » Mon Apr 22, 2019 1:56 pm
the Rambler has the most "complicated" front axle i built by now. Wheel, spacer, bearing, distance piece to hold the bearings, bearing, spacer, wheel.
but it runs nice now.
added 20g of thungsten fishing tackle on the sides of the motor. runs nice and smooth with the very light vac-formed body now.
also got some wheel inserts, i think they are quite nice, not perfect, but nice.
Postby taskak » Tue Apr 23, 2019 11:24 am
Looks good Peter, how about Nomad inserts painted with Molotow chrome to the Rambler.
taskak
Postby pfuetze » Wed Apr 24, 2019 12:31 pm
Nomad inserts, i need to have printed.
also the 7Star_engraved, which i was thinking about.
maybe next time i order @ shapeways.
Chrome? the Molotow chrome is sooooo shiny! i´m not totally sure how it will fit with more or less flat silver of the printed wheels.
worth a try for sure!
Postby pfuetze » Thu Apr 25, 2019 12:05 pm
wheel inserts for the 356 Porsche arrived today. painted them silver, now ready to install.
outer diameter is 7.6mm, so in real life, this insert is only a tenth of the screen size you are looking at right now!
Postby BARC 1 » Thu Apr 25, 2019 12:16 pm
Nice wheels. Molotow make a chrome spray paint called Burner 600. It dries duller then their chrome pens, but might work well for wheels. I use it as silver paint on cars.
This Porsche was painted with it
Postby pfuetze » Thu Apr 25, 2019 12:28 pm
Dan, great tip on the paint!
the Porsche looks awesome!
Users browsing this forum: No registered users and 35 guests
