Postby pfuetze » Thu Jun 22, 2017 10:23 am
Nice tires, Aki, where did you get them?
http://shpws.me/OHpp​
http://shpws.me/OHp3​
Randy asked if i can do the hybrid chassis for the Go!motor as well after doing it for the DSlot motor (or FF050 sized motors). Hybrid chassis? printed parts with a home made brass plate or styrene sheep plate.
designed for ball bearings (OD 4.76mm) and 2.38mm axles. bearing dummies (from shapeways) can be used instead of ball bearings, the printed material works great for this, i tried.
pattern file for drilling the holes can be sent by eMail or PM
screws for the chassis parts, i got from here: https://www.aliexpress.com/item/M1-M1-2 ... 23528.html
yes, M1.4 by 8mm screws - they work great for 1/43rd chassis.
Peter
Postby taskak » Fri Jun 23, 2017 3:27 am
taskak
Postby Dodgefarmer » Fri Jun 23, 2017 9:57 am
Thank you Peter. Hope you were able to make sense out of my wheel dimensions.
Randy
Dodgefarmer
Postby pfuetze » Sun Jun 25, 2017 3:22 am
thanks Aki.
yep, Randy, now i need only some time to design them ...
Postby taskak » Thu Jul 27, 2017 12:59 pm
taskak
Postby LloydL » Thu Jul 27, 2017 1:56 pm
You have been busy Aki, good work.
Regards, Lloyd.
LloydL
Postby ourwayband » Thu Jul 27, 2017 4:42 pm
Great looking Jouef Porsche..
Jouef are some of my favorite cars..
Postby taskak » Tue Aug 01, 2017 12:27 pm
taskak
Postby pfuetze » Wed Aug 02, 2017 6:14 am
great looking driver!
i like that steering wheel!
Postby pfuetze » Mon Aug 28, 2017 11:33 am
finally got enough popsicle sticks for a chassis.
but before i will have to build a racetruck for the 3-race-truck-proxy-series
Postby walker » Wed Aug 30, 2017 9:37 am
I like your attitude towards the hobby very much. :clap: :clap:
No beaten tracks, new ideas just for fun, that´s the right way. Great.
Roland
walker
Postby pfuetze » Fri Sep 01, 2017 1:53 am
Image​
[img]​https://s26.postimg.org/f3enq7yjt/2017-09-01_09_35_51.jpg[/img]​
[img]​https://s26.postimg.org/8n5p04q09/2017-09-01_09_36_09.jpg[/img]​
[img]​https://s26.postimg.org/fp3mmbtm1/2017-09-01_09_36_30.jpg[/img]​
a guy from Germany asked if it would be possible to do the hybrid chassis also for a boxer motor.
Well, it is possible, here are some pictures and the link to shapeways. The pdf file for correct drilling of the holes in the base plate will be sent by eMail or PM after request.
I´m using metric M1.4 screws from aliexpress to fix the parts to the brass (or polystyrene) base plate. i´m glueing a paper print of the drilling scheme to the base plate, drill the holes, make the cutouts for the motor and the gears.
Hybrid Chassis for boxer Motor (or Mabuchi SH030A)
http://shpws.me/OUTb​
http://shpws.me/OUTa​
Postby pfuetze » Sat Sep 09, 2017 12:43 pm
Image​
Image​
had to do a little repair work on my parma controller. after a drop the cable broke where it comes out of the controller.
so, cutting out 2" and soldering back together.
as the controller was open, i put a little epoxy on the windings after putting them in correct position. runs very smooth now.
Postby LloydL » Sat Sep 09, 2017 2:26 pm
I like that idea Peter!
Regards, Lloyd.
LloydL
Postby pfuetze » Sun Sep 10, 2017 9:02 am
started the chassis for the Buggyra Truck.
should start in the 3-race proxy in october - time to get going!
