Volvo 544 Rally Entry
Postby BARC 1 » Sat Aug 04, 2018 9:06 pm
After reading the rules and finding out my other entry did not fit, I set out to build an entry from a Volvo 544 resin shell Lloyd had traded with me some time ago.
The chassis is a Brass with Lego Axle Blocks. Bearings are mounted for the 2mm rear axle and the front 2mm axle runs through a brass sleeve. A Mineabea S can is arranged in an Anglewinder configuration. I am using one of Peters Slide Guides to allow the navigation of tight corners and am using BARC urethane rear tires
Car was painted to represent a 1960s entry into the Monte Carlo Rally.
A lot of weight has been added to keep the COG on this tall car as low as possible. The result is a car that is hard to deslot with a very predictable slide. I hope it is up for the Rally Challenge.
Re: Volvo 544 Rally Entry
Postby alexis in greece » Sat Aug 04, 2018 11:26 pm
Lovely work Dan ,where did you find the body?
alexis in greece
Postby BARC 1 » Sat Aug 04, 2018 11:56 pm
Lloyd and I made a trade for some 1/43 scale stuff. He might have more or know where this came from
Postby LloydL » Sun Aug 05, 2018 4:20 pm
Nice job Dan, will be interesting to see how it goes on the mountain!
I think I still have a bodyshell and will be casting some more soon.
Regards, Lloyd.
LloydL
Postby pfuetze » Sun Aug 05, 2018 11:46 pm
very nice work on the Volvo, Dan!
lights and details look great, an awesome car!
Postby taskak » Sat Aug 11, 2018 11:21 am
Very nice car Dan!
taskak
Postby masmojo » Fri Jan 25, 2019 1:29 pm
Sweet! :o
masmojo
Users browsing this forum: No registered users and 58 guests
