BARC Lexus SC400 redone
Postby BARC 1 » Sun Aug 20, 2017 10:08 am
Again with the proxy coming in the future I have been looking for cars that i will use. This Lexus competed in last years race but was off the pace. I like the car so I though I would build a new chassis for it. Very similar to the Gift card chassis, but instead I am using Brass plate. Lego blocks re used for Axle blocks, and the rear ones are fitted with flanged bearings. The motor is the Minebea S can that turns 16000 RPM at 12 volts. For proxy racing it is a little slow, but I have the ability to turn up my track to almost 14 volts and at that voltage the rpm is sufficient to get the most out of the motor. At 12 volts it just isn't fast enough and at 10 volts it is really anemic. However, like most of my cars they are built to run on my track and these motors are super for my needs.
CA glue is used to hold everything together that isn't soldered, and the bond seems to be really strong.
Re: BARC Lexus SC400 redone
Postby pfuetze » Sun Aug 20, 2017 10:42 am
nice work on the chassis!
the picture of the Lexus in the track is awesome!
great looking car!
Postby walker » Tue Aug 22, 2017 1:41 am
A nice rework.
I fully agree with Peter.
How much does the new, heavier model weigh now ?
Roland
DON´T LOOK BACK IF YOU DON´T WANT TO REALIZE WHAT YOU MISSED.
walker
Postby Cjent » Tue Aug 22, 2017 7:56 am
Great!!!!!
Cjent
Postby BARC 1 » Tue Aug 22, 2017 6:14 pm
I will have to weigh it when I get back home and let you guys know. I will weigh every car entered in the proxy
