I got the chip all wired up. To save space I got rid of the connectors and wired directly to the board. I used magnet wire for the front headlights as it is very fine and left the front wheels free wheeling. I needed to do this as the decoder wire was too big for the tight area around the headlights and front wheels
I had to set the speed to the lowest setting to get a decent throttle response. Might need a 50 ohm resistor to the motor to make better use of the throttle settings that are avialable
I zoomed around the small D132 set up with the car changing lanes and was happy with the lights and brake lights. Since the pictures were taken I added a rear mounting post and brought the back end of the car down to where is should be.
Decision is now made. All D132 track down the front straight transitioning back to GO track on either end. I have one Double crossover in the GO track and I may have to move the sensor on that to line up with the IR LED on the D132 chip
