Thanks! guys...
Power taps wiring is finally done , it was a much longer job then I though it would be , anyhow lets start the pictures...
I was having a hard time finding screw terminal in store near home or when I found one it was to expensive IMO so I came up with the idea of using phone jacks terminal it works great & cheap to buy
Here the phone jacks terminal & wire that I bought
Now I just had to remove the phone wire from the terminal & replace the screws in another hole to make some room between the wire connections
I marked lane #1&2 at every track that I have a power taps connected to & also under the table , I also marked the wires so I don't get them mixed up...
Now the fun of working under the table begins...
Here is where the power taps are located on the layout
BTW: The power supply & controllers are only temporary for now
Next the borders (aprons)...
Mikey
