I received my order of low profile tires in the mail today. They fit the RD wheels perfectly. Low profile to help reduce ground clearance. Two inside diameters so they fit tight on all of the wheels. Even the 15" diameter wheels. There is a grove molded into the face of the tires so the rubber sits flush with the outer face of the wheels for a more realistic look. This also makes the tread of the tires slightly wider. A great wheel tire combination from RD and KD.
Regards,
Frank
