Postby BARC 1 » Sun Sep 10, 2017 10:09 am
Can you give more info on the truck proxy. Lloyd mentioned it to me, but I haven't heard or seen much about it
Postby pfuetze » Thu Sep 14, 2017 12:37 am
Postby Dodgefarmer » Thu Sep 14, 2017 12:59 am
Peter, try using a 2mm axle to align the bore in the gear with the drill press chuck. Then dull (flatten or negative rake) the cutting face of the drill so it won't "grab" the existing bore in the gear.
Randy
Dodgefarmer
Postby pfuetze » Thu Sep 14, 2017 1:56 am
Randy, thanks for the idea!
the existing bore in the crowns is 1.5mm
i could use a piece of axle to align the crown, clamp it fixed, switch to the 2.2mm drill bit and drill the hole.
most of the crowns are off-center but nicely right angled, so my problem really seems to be the centering. With the 1.5mm axle, this problem should be gone.
Will try it in the evening and report, i got 3 crowns left to try :)
Postby pfuetze » Sat Sep 16, 2017 7:06 am
Postby pfuetze » Mon Sep 18, 2017 11:47 pm
Postby BARC 1 » Tue Sep 19, 2017 7:16 pm
Nice work as usual Peter. You build some fine looking cars.( trucks too!!!!).
I should have tired to get something together for the Truck Proxy, but I think I am out of time. I think I have some old Artin Trucks somewhere. Should see If I can get something built from one of those.
Postby taskak » Wed Sep 20, 2017 3:37 am
taskak
Postby pfuetze » Wed Sep 20, 2017 6:04 am
great Porsche, Aki!
nice lights! they always add to the look of a car!
Dan, Artin trucks are fun, but they need a rotating guide! (part of the ProNoMag rules)
i will send an eMail regarding the Kleskun Hills Fun Run shortly.
Postby BARC 1 » Wed Sep 20, 2017 7:05 am
Nice Porsche Aki. One of my favourite cars
Peter,
I would build a chassis and just use the Artin Shell
Postby pfuetze » Fri Sep 22, 2017 12:52 pm
Postby taskak » Sun Sep 24, 2017 10:53 am
taskak
Postby LloydL » Sun Sep 24, 2017 11:11 am
Very nice build Aki!
Regards, Lloyd.
LloydL
Postby BARC 1 » Sun Sep 24, 2017 5:55 pm
Agree with lloyd. Very Nice build on the VW truck. Something I really like about brass.
Postby pfuetze » Mon Sep 25, 2017 1:06 am
nice chassis wok, Aki!
great to see that we will have an international truck proxy!
nice find on the plastic truck body!
