Home Racing World • View topic - Ford-Porsche Wars Proxy - Rules & Registration
Here we go! Round #2 in what started last year as a proxy duel between both builders and marques.
Re: Ford-Porsche Wars Proxy - Rules & Registration
Postby Audi1 » Wed Apr 12, 2017 11:44 am
Postby F1Fan » Wed Apr 12, 2017 12:11 pm
Hi Allan
With this many cars entered, can you confirm that host's will have to 1) complete the event on the same day 2) the order for racing, will it be by discretion of host, car number or qualifying 3) is there a minimum/maximum race time for each car at each event 4) will each car be driven by each driver for an equal amount of time?
Asking because hosting a proxy with this many cars (if they all show up) will be time consuming and hosts might time out on the event on the same day, which could impact the performance of the cars, the track conditions and the availability of the same drivers. E.g. track grip could be very different for car 46 if cars 1 through 45 - each race 8 mins prior!
Chris
F1Fan
Postby Z-carfan » Wed Apr 12, 2017 12:15 pm
Postby Audi1 » Wed Apr 12, 2017 4:48 pm
Postby gascarnut » Wed Apr 12, 2017 4:55 pm
gascarnut
Postby Z-carfan » Wed Apr 12, 2017 8:34 pm
gascarnut,
That actually sounds like a cool idea, Porsche one day, Ford the next, Top 5 of each side go to a final round to determine a winner. ( My vote is YEAH). :auto-driving: :banana-dance:
Postby CrockettNZ » Wed Apr 12, 2017 11:55 pm
the way we normally run proxy's here are the cars have qualifying one day
and then the big race in the next fews days after that
and then they race in groups of 3 or 4 depending on how many lanes the track being used has
each group will run all heats for their race at once
starting with the slowest qualifiers working up to the fastest qualifiers
that makes it easier to get track
we have the same driver on the same lane for all cars and use the track owner and best drivers that are available on the day
one guy focused on putting all the data in the computer and 1-2 guys focused on getting the right cars on track and in the right lanes
plus the right lane sticker as well as cleaning the tires with the sticky tape board
as for the time each heat length will be will depend on how many cars there ends up being
hope this works well for you
CrockettNZ
Postby Audi1 » Thu Apr 13, 2017 4:16 am
That qualifying/racing format will be fine for this series, CrockettNZ. It's very similar to what other hosts will do.
Postby Mitch58 » Thu Apr 13, 2017 6:18 am
That's how we run proxies here in the Portland area. If we have a proxy with multiple classes we may switch drivers between classes, provided we have enough people, which we usually do. If any of us are participating in a particular class of a proxy, they will typically marshal during that class, again providing we have enough other drivers.
Mitch58
Postby urbanwarrior » Thu Apr 13, 2017 2:39 pm
Allan I'm going to go with Ford 73 and Porsche 83. Hope they work.
John
urbanwarrior
Postby Audi1 » Thu Apr 13, 2017 5:49 pm
John, those two numbers are yours. Have fun building them out and good luck in the racing!
Postby F1Fan » Sat Apr 15, 2017 10:49 am
Allan,
Minimum clearance 1.2mm
Does this measurement include the crown gear? [Apologies if this was asked before, in some proxies the rule is without the gear, others not]
Chris
F1Fan
Postby Audi1 » Sat Apr 15, 2017 1:34 pm
Hi Chris,
No, crowns and spurs can be lower; as long as they don't represent a physical threat to any of the tracks that we run on. The 1.2mm is the minimum clearance on the underside of the chassis or on any weight that is attached to the bottom of the chassis.
I should add that we would prefer all weight to be above the bottom of the chassis (inside the car), since external weight, in some cases, tends to come off during a long proxy series and can cause damage to both the host tracks and the other cars.
Postby Audi1 » Mon Jun 12, 2017 4:42 am
Those of you who still need to choose your numbers, or designate your car(s)/number(s), this might be a good time to do that. Registration fees will be due in August and that will be coming up sooner than you think............ :lol:
Here are the pre-registrants that I still need info from:
Aloha - Ford TBD / #4 - Porsche TBD / #5
BrumosRSR - Porsche TBD / #33 - Porsche TBD / #111
Redlynr - Ford TBD / #12 - Porsche TBD / #16
Steeveew - Ford GT-40 / #8 - Porsche TBD / #65
Slotting Since 1963 - Porsche TBD / #63
Charley - Ford GT-40 / #TBD - Porsche TBD / # TBD
Smokeio - Ford TBD / #70
F1Fan - Porsche TBD / #7
Midagekid1 - Car TBD / #15
Yebo - Ford TBD / #54
Chrisguyw - Porsche 908/3 / #TBD
ckouba - Ford GT-40 / #TBD - Car TBD / #TBD
Hillbilly - Ford TBD / #17 - Porsche 917 / #18
Postby redlynr » Mon Jun 12, 2017 5:13 am
Redlynr - Ford MKIV / #12
No Porsche, development is not proving competitive...
redlynr
Return to Ford-Porsche Wars Proxy 2017
