Home Racing World • View topic - 1/24 sprint car
1/24 sprint car
Forum rules
Open to ALL SCALES!
1/24 sprint car
Postby CrockettNZ » Fri Mar 03, 2017 5:00 pm
one of my club mates picked up a box of sprint car model parts of of ebay awhile back
he was planning on building up a sprint car slot car
I had those same thoughts in the back of my head for awhile myself so was very interested
he has now lent me the box of bits to see what I can come up with
well after sorting out what was what and what goes where I found myself with the wire and solder out up before I knew it
I was under way
this is where I am up to after a week of playing around each night
it will be the wingless version as shown below but of my own livery
will update as progress happens
I do need to sort some wheels and tires so I can get my front/rear axles plus guide mount set up
CrockettNZ
Re: 1/24 sprint car
Postby btaylor » Fri Mar 03, 2017 5:19 pm
I like this! keep the pics coming.
Re: 1/24 sprint car
Postby RazorJon » Fri Mar 03, 2017 11:52 pm
That's a fine job, glad you gave it a go
Re: 1/24 sprint car
Postby CrockettNZ » Sun Mar 12, 2017 2:30 am
ok I have got the chassis to this point and now only need to set up the guide mount
this chassis has got away on me and has been a lot of work time wise
but I have to say it has been a very good learning curve
then it is time to get it painted and then onto fitting a motor,driver and body work etc
CrockettNZ
Re: 1/24 sprint car
Postby CrockettNZ » Sun May 07, 2017 3:27 am
I have now got this car finished
it was a massive amount of work and I am fairly happy with it
CrockettNZ
Re: 1/24 sprint car
Postby RBPhillips » Sun May 07, 2017 6:57 am
You should be pleased with your work - absolutely unreal!
RBPhillips
Re: 1/24 sprint car
Postby btaylor » Sun May 07, 2017 7:56 am
Fantastic! That is one sweet build.
Re: 1/24 sprint car
Postby GASSERMAN » Sun May 07, 2017 1:32 pm
You did a beautiful job. Keep them coming. Bob..................
GASSERMAN
Re: 1/24 sprint car
Postby HomeRacingWorld » Sun May 07, 2017 2:54 pm
Outstanding detail. Well done. :auto-checkeredflag:
Re: 1/24 sprint car
Postby CrockettNZ » Sun May 07, 2017 3:46 pm
thanks guy's
CrockettNZ
Re: 1/24 sprint car
Postby Broman62 » Sun May 07, 2017 6:16 pm
Spectacular!!! What an awesome brass job plus the whole car build up!!
Re: 1/24 sprint car
Postby strangebrew » Sun May 07, 2017 8:53 pm
strangebrew
Re: 1/24 sprint car
Postby CrockettNZ » Mon May 08, 2017 4:08 am
CrockettNZ
