Home Racing World • View topic - Bounty Hunter
Bounty Hunter
Forum rules
Open to ALL SCALES!
Bounty Hunter
Postby Austin » Wed Mar 01, 2017 1:54 pm
Country Girl the Bounty Hunter is looking for you !!!!
Parts
Piano Wire SCC
MPC Bounty Hunter Funny Car Kit E-Bay
XPG 1/24 Drag Racing Tires (Wide) SCC
PARMA PSE MOTOR low rpm home set motor No one around here has any parma motors for the class :doh: I Had
WRP D3 Retro Motor Bracket SCC
Alxe Bearings I Had
tube under chassis for drop arm to be added later, no need now motor to weak. SCC
Rear 1/8 axle SCC
Rear wheels I Had
Wires Just on the bench
Rear tires tuned with Hudy tires tuner.
Gears SCC
Austin
Re: Bounty Hunter
Postby nhdungeonracer » Thu Mar 02, 2017 7:12 am
