New Forum - Build OFF! '18
Forum rules
Open to ALL SCALES!
Re: New Forum - Build OFF! '18
Postby slothead » Tue Feb 20, 2018 11:43 am
Clive
Not sure if you are only interested in production cars used for racing, or absolute thoroughbreds built only for racing. If the latter is okay here's my challenge:
Shadow DN4A from 1974 - 75
Now that I'm Can-Am crazy this is my dream slot car. If you make it I promise to buy at least 2, the #101 & #102.
Slothead
slothead
The Doctor is IN!
Postby Ky.Slot Racer » Tue Feb 20, 2018 12:09 pm
that car looks great, but it seems it would be very hard to get the guide in a decent position without distorting the body. Unless your ok with having the pivot point behind the axle. :think:
Ky.Slot Racer
HRW Master Modeler
Postby CARacing » Tue Feb 20, 2018 10:09 pm
SUPER!
Thanx Slothead, I'll start with my research and post as I move along.
Thnk you for the challenge.
CARacing
Postby slothead » Tue Feb 20, 2018 10:52 pm
The Slot.It chassis under the Ferrari 312 PB has a very low guide post located just in front of the front axle that I think would work under a body like the Shadow. The guide post top is just below the front axle height. It may be a variant of \the EVO6 Slot.it chassis.
This is an image of the Slot.It Chaparral 2E chassis, which is similar.
Clive - if you need a chassis like this to experiment with I can send you the Ferrari 312 PB one I have to check out.
Slothead
slothead
The Doctor is IN!
Postby CARacing » Wed Feb 21, 2018 5:25 am
Thanx Slothead,
I will keep in mind and give you a shout should i need it. We'll make a plan / improvise.
CARacing
Postby CARacing » Sun Feb 25, 2018 1:36 pm
Hi All,
Slothead, here is where I'm at...
Lots of pics, but no dimensions, nor blueprints as there where only 5 of these car built.
I see lots of 1:43 models, but not any 1:32 slotcar models.
so, CARacing presents, Shadow DN4 custom made...I'm giving the clay a first time try and not wood as usual. The next couple of days will be setting/curing time for the clay and then the silicone mould will come after.
Hope this attempt at your favourite car meets your expectations...
CARacing
Postby CARacing » Sun Feb 25, 2018 1:44 pm
CARacing
Postby CARacing » Sun Feb 25, 2018 1:45 pm
Sorry, I do not know how to post a pic here...what to do?
CARacing
Postby HomeRacingWorld » Sun Feb 25, 2018 1:50 pm
Right click on the photo and use copy image address. Then press the little button up there that looks like the mountain with a sun.
Paste that URL you copied in that box.
Postby CARacing » Sun Feb 25, 2018 2:10 pm
Hi Harry, please could you help with my TAPATALK activation for CARacing?
The message I keep on receiving is "waiting for administrator to activate account" for Home Racing World. I always used to use TAPATALK which worked wonders for me. Please help.
CARacing
Postby Jesla » Sun Feb 25, 2018 2:26 pm
TapaTalk is now a paid service for websites. It is being dropped by more and
more sites including this one and my website.
Jesla
Postby HomeRacingWorld » Sun Feb 25, 2018 2:49 pm
Yes, unfortunately TAPATALK has become more of a nuisance than a resource. Not just the fees, but the updates and support are literally gone.
They shut off support for this site without warning, and almost like Photobucket, held us "hostage" for fees.
No dice.
Try Postimage to post quick pics. Free and and easy.
Postby HomeRacingWorld » Sun Feb 25, 2018 2:50 pm
It took 5 seconds to right click on your Google photo and post it here. Just FYI.
Postby dw5555 » Sun Feb 25, 2018 4:07 pm
Still don't see it
dw5555
Postby CARacing » Sun Feb 25, 2018 10:13 pm
CARacing
