H.O. Build-Super Modified
Forum rules
Open to ALL SCALES!
Re: H.O. Build-Super Modified
Postby kcl » Wed Mar 15, 2017 2:50 pm
Added a few things, started working on a small cowl in front of the cage also the
cage looked like it was missing something so we added a small headrest to it.
Gathering up some parts to try out and see what works.
Have a couple sets of injectors to try and found a head for the driver, his body came from the
same car that supplied the tail piece and the other parts from some other cars in the junk box. As with most
things in HO, parts either have to fabed or swiped from other cars.
Planning to use these wheels on the car, they are Road Race Replica wheels. I usually
use stock wheels, but I think these will look better than the Turbines on the finished car
and they are chrome. We'll save the other ones for something else.
All for now
Kevin
kcl
Postby ShotgunDave » Wed Mar 15, 2017 10:37 pm
I am still in awe of the amount of detail you pack into such a small car.
Nice work Kevin.
ShotgunDave
Connoisseur of Rust
Postby kcl » Sun Mar 26, 2017 7:39 pm
Started working on the roof for the little Super Mod. While looking around, thinking I may have to scratch build
one, ran into an unlikley donor. Found an old Peterbuilt truck in the parts box and borrowed the roof from it.
After cutting the roof off, fitted it up and cut the back window out.
Worked out well and attached it to the body after filling the holes the the pipes went into. Still in the drying process
and will add filler as it drys and shrinks.
The roof gives the right effect to the body for this style car. We'll sand this first pass of filler and proceed
from there. It's coming along little by little.
All for now
Kevin
kcl
Postby dge467 » Sun Mar 26, 2017 7:41 pm
Really coming along nicely!
Postby clivearmstrong74 » Mon Mar 27, 2017 7:08 am
I like this little car!!! Super work!!
Clive
clivearmstrong74
Postby kcl » Sun Apr 23, 2017 5:08 pm
Got back to working on the Super Mod this morning. Cut a hole for some injectors in the hood.
Centered the injectors and traced around the out side. Then flipped them over and traced
around the stack portion to get a guide line. With the body on the frame for support, drilled
some holes to open up the hood.
After some file work and some test fitting, wound up with a hole that the stacks would fit through
and left the bottom of the stacks to mount under the hood.
Now we have a set of injectors that just stick through the hood, but not higher than the little cowl
piece in front of the cock pit. A nice peaceful morning with coffee and the radio.
All for now
Kevin
kcl
Postby kcl » Mon Jul 03, 2017 8:23 am
After getting past some real life issues, finally had a chance to work on the car.
Started on making some bumpers for the car.
Started by making a couple of small u-bends. These will then be attached to the frame.
These will extend the frame and act as an attachment point for the rest of the bumper.
Still a long way to go but getting back into the swing after being away for awhile.
All for now
Kevin
kcl
Postby TuscoTodd » Thu Jul 06, 2017 8:45 am
Shaping up NICE!!!
:D
Postby ShotgunDave » Thu Jul 06, 2017 9:31 am
I'm still amazed every time I see your work. Well done!
ShotgunDave
Connoisseur of Rust
Postby kcl » Thu Jul 06, 2017 6:26 pm
Thanks for the kind words.
The u-bends are intalled and part of the bumper. Holes were drilled in thr rear of the frame and the u-bends
fitted into the holes. After drying they were sanded up and the first part of the bumper was attached
to the u-bends.
With the body on, there is a little room to work with and a couple more bars will be added to form the bumper.
These will be placed above and below the center bar to fill the space in the middle.
Car is starting to shape up and once the rear is done, we can move to the front.
All for now
Kevin
kcl
Postby dge467 » Thu Jul 06, 2017 6:31 pm
Impressive work as usual!!
Postby kcl » Sun Jul 09, 2017 10:15 am
Finished the rear bumper. Two bars mounted to the center bar and the u-bends completes it.
These are all made from paper clips cut and ground to fit, they fit the scale well and are easy to work with.
Attached with super glue, since soldering is impossible cause of the size and the chassis being plastic.
Bumper tucks up under the body just at the edge and fits the car well. A little more clean up and
we'll move on to the front and work on that.
All for now
Kevin
kcl
Postby kcl » Sun Jul 16, 2017 9:15 am
Well the picture police have caught up with me.
I'm hoping to edit the thread as time permits and try to get back on track.
It's to bad a lot of good infomation on these threads has to go
to waste because of greed.
All for right now
Kevin
kcl
Postby kcl » Thu Jul 20, 2017 5:55 pm
Well I have spent the last few days editing this thread only becacuse it's a buid off thread.
Been using Imgur and it acts a lot like photo bucket as far as using the album part of it.
So far been happy with it. I would like to thank photo bucket for all the extra work
it has caused everybody that had used them and for screwing up a lot of the extra
if any build time many of us have. Ok enough rant, do have a couple more of the rear.
Maybe I can get back on track and catch up on the front over the week end.
All for now
Kevin
kcl
Postby JT Previa » Thu Jul 20, 2017 8:01 pm
Love the micro-soldering and creative kit bashing. A shame to hide that roll cage with the hard top though...
JT
NERF Slot Racing Massachusetts
JT Previa
