My 2017 build started
2017 Trans-Am Series (Retro Racer 44) Proxy Information
Re: My 2017 build started
Postby clivearmstrong74 » Mon Jan 09, 2017 4:43 am
Hallo to All,
CARacing has finished the 1970 Pontiac firebird, based on the nr8 Jerry Titus car. and here is my story:
I started with blueprints from the net and made a buck from wood. Silicon mold was made and resin body was slosh cast.ImageImageImageImageImageImage
Clive
clivearmstrong74
Postby Audi1 » Mon Jan 09, 2017 5:51 am
Nice job of modeling that car, Clive! Will be following this build closely.
Postby BARC 1 » Mon Jan 09, 2017 8:41 am
This is looking like a true scratchbuild.
I am watching with interest
Postby Radarek » Mon Jan 09, 2017 9:35 am
Some serious modeling here.
Looking forward to see how it goes.
Regards Dariusz aka radarek
Radarek
Postby clivearmstrong74 » Mon Jan 09, 2017 11:34 pm
lots of hand crafting, sanding, filing and smoothing the body.ImageImageImageImage
Base coat was applied by airbrush and the interior was made from clay, which was resin coated and painted. The roll cage was made from the insulation of electrical wire - copper removed and painted.
Clive
clivearmstrong74
Postby Austin » Tue Jan 10, 2017 7:09 am
Clive, looking very nice, a lot of skill goes in to work like that. Loving it.
Austin
Postby strangebrew » Tue Jan 10, 2017 9:17 am
True scratchbuilding...... :clap:
strangebrew
Postby glasshorsevh » Tue Jan 10, 2017 2:54 pm
This is a crazy-good! I guess I can't really call what I do scratch-building now...
Fascinated Val...
glasshorsevh
Postby clivearmstrong74 » Wed Jan 11, 2017 1:28 am
Windows were cut from clear plastic sheet. Decals were done by my very own Graphic Designer (my Brother) and came out super!! Thanx Gavin!!!!! The original driver was fired....bad driving...and replaced with a new more appropriate driver. The driver and dash were sculpted from prestik, frozen and then created silicone mold...resin cast and hand painted.ImageImageImageImageImage Lots of work, but satisfying!
Clive
clivearmstrong74
Postby Broman62 » Wed Jan 11, 2017 8:59 am
Now that is some true scratch building... looking forward to seeing it done!!
Postby clivearmstrong74 » Thu Jan 12, 2017 3:19 am
Chassis built from pvc sheet (1mm), running gear, axles and wheels were all vintage (1964 date on packaging) All new/old stock. The final adjustments, lubes, etc were done and she was posted off to David.
This was a very satisfying and rewarding hobby for me. To see the end product is awesome...not perfect, but awesome!!!
From this:
to this:
Thank you to ALL the replies and comments!!
Clive
clivearmstrong74
Postby Audi1 » Thu Jan 12, 2017 12:35 pm
Very, very nice job!
Return to 2017 Trans-Am Series (Retro Racer 44) Proxy
