As the storm was passing over-head yesterday, I took the opportunity to work on some projects that I had been putting off and ran in to an issue that I haven't seen discussed here before. On two separate cars, I found wobbly plastic wheels. What I mean by this is that it appeared as though the hole in which the axle resides was drilled at a slight angle. The axles were straight, but one of the wheels wobbled around as though it were only held on by a single lug nut. I have both a Cartrix and Revell-Monogram with front axles suffering from this affliction.
In the way of a fix, I'm wondering if it is worth trying to drill a straight hole for the axle and then just gluing the wheel on, or if I'm just better off scrapping them and rolling the dice that the next axle set that I buy will be properly drilled. Has anyone else encountered this problem and if so, what did you do to resolve it? Thanks.
