About two years ago when I was getting started with 1/32 slot cars I got hold of the R/M McLaren M6A, Denny Hulmes ride. I also had a copy of a slot car magazine that featured the R/M car and the article showed a way to get the body lowered to a more realistic stance. It involved trimming the body mounting screw posts so that the front wheels would sit deeper in the wells. But it also invlved careful trimming of other components to allow the chassis to fit further up into the body shell. What was already a tight fit became even tighter and arranging things like the guide flag and the lead wires was difficult at best. I followed the instructions in the article and ended up with the body sitting a little lower and no flex between the body and the chassis. Recently, I got the red #11 McLaren in one of Electric Dreams 2-fer deals. I initially decided I would leave the body height alone and not try trimming the screw posts. One day when I had the car apart I noticed that the front axle had its own nylon bushings instead of just holes in the chassis. I also noticed that when sitting on a test block the guide flag was only about half way in the slot. That's when I got an idea. I opened up the retainers for the nylon axle bushings so they could slide up or down and thereby adjust the ride height. After the openings were trimmed I mounted the front axle with hub and tires installed and set the car on my test block. Then I pushed down on the guide flag until the braids were flat on the test block. The nylon bushings had moved up in their carriers about 1/16", I looked at the bottom of the chassis and it still had more than legal clearance so I then CA glued the bushings in place. All I had to trim on the body this time was the inside of the wheel wells where the bottoms of the mirrors poked through. I also had to trim off the mount for the screw that held the car on the base it came on and the bottom of the magnet pocket that protruded below the bottom of the chassis. Now with the body all buttoned up there is room for a little flex, the front wheels spin freely and the car has a much better stance. The CG is also significantly lower. Here are some images illustrating what I did, inluding a before shot.
