track lighting
track lighting
Postby oldtymer » Tue Jun 18, 2013 7:21 pm
Just built a new Carrera Digital layout . I built a replica of a road course in Spain . Its on a 18x8 table and has 80ft of track . Does anyone have any ideas for lighting around this type of layout for night racing ? For example : tower lighting , pole lighting or any linear lighting around the outside .
oldtymer
Cat Lovers Club Prez
Re: track lighting
Postby RichD » Wed Jun 19, 2013 5:54 am
You could do something like this.
Or this.
Re: track lighting
Postby oldtymer » Wed Jun 19, 2013 12:05 pm
RichD...those are really sweet...if you have time can you just explain the first one . Are the pole lites homeade ? Thanks , very nice setup too .
oldtymer
Re: track lighting
Postby SlotCarCorner » Wed Jun 19, 2013 12:58 pm
I'll defer to Rich to describe how he made the pole lights (I've "seen" Rich's pole lights - they are very nice). The lights in the first picture are flexible LED light strips - they come in various colors and typically sold by the foot or in 5 meter (approx. 16 ft.) lengths. Do a Google search on "LED light strips" to find them. They come in various colors and "shades" of white (e.g. warm, daylight, bright, etc.). The strips are designed to be cut if desired - they are marked every 2 or 3 inches to show you where to cut. In Rich's picture, the driver's stations are to the left - the lights were installed so they would not shine directly into the driver's eyes (i.e. the lights all face to the "right" or away from the drivers stations). The strips come with a self-adhesive strip that makes installation very easy - just peel away the backing and press in place.
Wiring is easy too - you can buy special prewired "dongles" that slide over the edge of the strip and lock in place or just solder a couple of wires at designated points along the strip. Connect to a 12VDC power source and you're in business. Be sure to get lights designed for 12V.
Hope this helps.
SlotCarCorner
Re: track lighting
Postby oldtymer » Wed Jun 19, 2013 3:21 pm
Yes it did thanks....I was wondering if anyone has seen light towers with multiple lights to place in the infield....I will check on the LED strips
oldtymer
Re: track lighting
Postby arroldn » Wed Jun 19, 2013 4:36 pm
arroldn
Re: track lighting
Postby pgtr » Wed Jun 19, 2013 6:55 pm
...any additional pix of the first track? Perhaps with lights on (or not) from different angles. It's a nice track!
Thanks
pgtr
Re: track lighting
Postby olskoolslotz » Wed Jun 19, 2013 8:49 pm
olskoolslotz
"THE Champ"
Re: track lighting
Postby oldtymer » Thu Jun 20, 2013 5:35 pm
Thanks olskoolslotz....have you seen them used on a 1/32 scale track ? do u think they are bright enough ?
oldtymer
Re: track lighting
Postby olskoolslotz » Thu Jun 20, 2013 7:46 pm
olskoolslotz
"THE Champ"
Re: track lighting
Postby oldtymer » Thu Jun 20, 2013 7:53 pm
ok thanks
oldtymer
Re: track lighting
Postby RichD » Fri Jun 21, 2013 5:42 am
Re: track lighting
Postby SlotCarCorner » Fri Jun 21, 2013 5:59 am
Great write-up on your track lights Rich - thank you for posting!
SlotCarCorner
More Pictures
Postby RichD » Sat Jun 22, 2013 5:42 am
