Home Racing World • View topic - Tape over existing
Tape over existing
Tape over existing
Postby Billy boy » Fri Aug 16, 2019 2:13 pm
Here’s another question. I’m getting breaks in my copper tape. I’m thinking of taping over the original tape. Am I just compounding the problem ? The space was previously not climate controlled but A/c has been installed and heat is next for winter.
Billy boy
Re: Tape over existing
Postby slothead » Fri Aug 16, 2019 4:18 pm
slothead
The Doctor is IN!
Postby frank9129 » Fri Aug 16, 2019 5:02 pm
I have had my track outside for years. It stays in my car port covered by a blue tarp.
I get the occasional break in the tape but it is not from weather. KIDS, they are rough on a track.
Three years ago I damaged the track and had to do a major repair. I scraped all the tape (original) gave the track a light sanding and refinished it. Once the paint was dry, after 3 days, I started laying the tape. Rather than using the standard copper tape I used guitar shielding. It is a little more expensive and has conductive adhesive.
Now when I get a break I repair it with a small piece of tape and burnish it good. That's it.
frank9129
Postby waaytoomuchintothis » Fri Aug 16, 2019 9:59 pm
Over the years I have discovered the guitar shielding tape, too. When I build a new design Strat for my son (he does custom design guitar circuits for folks, I'm just the woodworker- some HRW folks will remember the custom Strat I made for myself from quilted maple and rosewood), the customer decides what the body wood and the neck wood will be, and I build it accordingly, including my son's fancy circuit. I line the pickup cavity, the underside of the pick guard, the tunnel to the pots and switches cavity, and the bridge pocket with that same copper shielding Frank is talking about. It is more expensive and thicker than the copper tape used on slot car tracks.
Postby Billy boy » Sat Aug 17, 2019 6:00 pm
So I have so many repairs that I thought I’ll just go over it all with new tape. Anyone ever do this and how did it work out.
Billy boy
Postby mattb » Sat Aug 17, 2019 6:33 pm
Clean the old braid good, alcohol or mineral spirits, let it dry good and you can probably tape right over it with no issues.
mattb
Postby HomeRacingWorld » Sat Aug 17, 2019 7:31 pm
You can. Follow the cleaning tip.
But you will need to SOLDER at some point.
Watch the video.
Users browsing this forum: No registered users and 168 guests
