I continue soldering together ideas for the 2020 GT3 qualifying run. This attempt is wire and brass in a sidewinder configuration. Bearings on all axles with independent front wheels and a lightly sprung drop arm have resulted in a smooth consistent runner that I cannot flip in testing. Not sure what others think, but my reason for the drop arm is this chassis has no pod, and the thought is a drop arm allows some degree of the same thing a pod offers a car. I.e some movement to allow better handling.
Wheels are 50 year old Cox magnesium rims, with NSR rubber glued on
Chassis has an adjustable wheelbase, and motor mount to easily change motor and gear set ups.
